| i wanted to add this question to a previous posting, but it seems that if you reply to an old post, it doesn't move it up, so noone would ever see it...
if one winds a coil, and it is a little smaller in overall dimensions than it should be (ie wound too tight), how much difference does this actually make in voltage generated?
let's say the magnets are 2x1, and the coil ends up 1/8" too small all the way around..155 turns. would there be enough difference in the amount of wire used to make any difference in output? does the actual amount of wire in a coil make much difference or is the # of turns the most important thing? i can't see there being very many feet of wire to make the coil slightly bigger, but then again, i never calculated how much wire would be in a coil of the smaller size. i suppose if the small coil had 100' and 10' was used to make it the 'right' size, that's a 10% increase.
i did a brief google search for this info, but didn't find anything good about it.
thanks. |
107 Scoop users have viewed this posting.
