LiFePO4
By commanda, Section Diaries Posted on Wed Aug 26, 2009 at 07:17:52 AM MST
LiFe (PO4) on the bleeding edge
| These turned up today.
8 x 90 AHr Thundersky Lithium Iron Phosphate (LiFePO4).
Manufacturers website here: http://www.thunder-sky.com/products_en.asp
Here I have configured them in 2p4s, for a nominal 12.8 volt pack at 180 AHrs. Cost to my door was $1405 Aussie dollars.
Dimensions are 490mm x 145mm x 230mm, and weight approx 25.6 Kg.
The manufacturer rates these at 3000 cycles for 70% DoD. Almost 10 years on a daily discharge cycle. If one uses the lead-acid principle of never more than 50%, they should just about last forever.
Next step is to finish the physical hookup of the control electronics, which will be detailed in the next installment.
Amanda |
