| Well, after all sorts of issues and life in general I've Finally got the 3HP 3PH conversion in the air. No thanks to one of our horses finding it necessary to play in the guy wires, that hurt progress for a while. Anyway, it's finally up and running now for my question.
http://www.fieldlines.com/story/2007/8/27/51542/1469
http://www.fieldlines.com/story/2007/8/28/51444/7540
So it's in the air and spinning like crazy right now, high winds here.
It's clamped at battery voltage, 24 volt system, but only 3 or 4 amps output with surges to 7 or 8A.
It's wired Y and I'm trying to remember what it was that Zubbly told me about using Y, Delta or Jerry for advantage, but surely can't remember and can't find the notebook with all those notes in it.
So I'm wondering what might be a good course of action to increase output, if I can.
I've got Zubbly's chart from his conversion diary and it's what I use to make my connections.
Don't know much about Jerry connection or how it would apply here, if so?
This is the set up I made for my connections, so it's pretty easy to make changes.
The blade set I made are 12' diameter TSR 6, at least that's the design I used.
Below is a picture of the blades being balanced in the shop.
118 Scoop users have viewed this posting.
