| Hello,
First post here. I have been given an old engine driven generator that uses a permanent magnet rotor and two stationary coils. It's a McCullagh 'MightyLite'. Made in California. The engine is broke.
I cannot find any info. on the machine to tell me what engine revs should be to give 50 Hz (or 60 Hz).
In order to get 50 Hz from this generator what speed do I need to rotate the generator at?
I am going to guess 50Hz X 60Sec / 2 = 1500 rpm??? 3000rpm seems too much for the engine to be doing (guess).
The coils are connected in series but they appear to be wound in 'opposite' directions. (Since each winding will always have an opposite pole going accross it, this is the correct way to connect them...I think)
Would this device be suitable for connection to a wind turbine? I guess not unless with a gear box and then you
have to drive the gear box (lose energy).
This information is no doubt already on the board but I am dammed if I can find/figure it out.
See the attached drawing of generator.
Guinney
[IMG]http://i628.photobucket.com/albums/uu10/guiney12/generator.gif[/IMG] |
