Recomendations for SHW in WI
By mojisimo, Section Water Posted on Wed Sep 30, 2009 at 08:47:54 PM MST
Need recommendation for % glycol solution to use in drain back system in WI with 300 gal tank. I am also looking for opinions on using a pressure vent on top of panels.
| I have two questions:
- Do you have a recommendation for % glycol solution to use in cold Northern WI. The temps are extreme. I have heard 30-50 % and at $21 a gallon 50% is hard to stomach. The system failed this past winter (innards of 6 concentrating SolarGenix panels burst, could have been many different reasons why they burst and we are going up to address them this next week). So I want to make it more burst proof in the future and think that adding glycol is a good idea. I would like to get away with 30% but don't want to invest in the 30% if it is going to end up falling short, might as well go with closer to 50% in that case. What do you think?
- We have a pressure relief valve at the drain back point at the top of the last panel. It is a 125 psi air/coin vent. Should that not be there in our cold climate?
Thanks!
Mike Dooraghi
57 Scoop users have viewed this posting.
