| I'm throwing this into the group for discussion or maybe someone will give it a try.
Most homes have water under pressure delivered right to the tap. Somewhere down the pipe other pipes are met and at some point there is a constant flow of water, so why not use the pressurized water flow to turn a generator before the water is delivered to it's destination? Even small generators that only run when a tap is on might be useful for battery charging. That's it.
Never stop having fun. |
163 Scoop users have viewed this posting.
