I can relate to everything you've said. When I was in high school doing a course in how to wire up light switches we each had seperate panels, when the instructor was satisfied that it was wired properly, we could plug it into a fused receptacle to see if it worked. I'd be working on my circuit and swear that I'd got a shock yet how could I when it wasn't even plugged in?
Another time I connected a 110v motor to one flashlight battery to see if it would turn at all, nothing, disconnected the battery and touched both prongs of the plug....WOW surprise! It was there that I learned that you can store a charge in other things besides capacitors.
Now for the lab kit...have you tried Goodwill, Salvation Army, swap shops for a used one? I remember that I saw one just like mine (201 projects) for $1.00....senior citizens day half-off...but I didn't buy it because I already had one. Next time I'll keep people like you in mind.
Right now you probably don't believe you could learn how to rewind a small electric motor either ...right?
I didn't either, but I do now. I took a mini-motor apart....2 magnets..3 windings..3 commutator bars...unwound it,counted the number of turns, got some slightly heavier wire, rewound it in the same pattern and sucess.
Lot of stuff for us to learn together!
Stop in at my website once in awhile (not too often...I move very very slow, 'Mule Train')
Don't hesitate to ask questions.
Thanks for your interesting reply!
( :>) Norm.
