Author Topic: Real Ruff Draft of FSW Inverter  (Read 1213 times)
ibedonc
« on: March 03, 2004, 09:02:58 PM »
http://www.otherpower.com/images/scimages/348/fswinverter.pdf
this give you a idea were I am going , the 60hz sine ref. works , I am waiting on parts
to start building .
I will be proto'ing the LM4651 to make sure it works , I have come up with a feedback
loop to control the voltage output level to get it at 240/120
« Last Edit: March 03, 2004, 09:02:58 PM by (unknown) »
RobD
Re: Real Ruff Draft of FSW Inverter
« Reply #1 on: March 08, 2004, 10:16:06 AM »
Hi Don,
A couple of questions on the schematic.
What's the signal coming out of the 4651 a pulse steam or a sine wave? Are you using it to develop the pulse train?
You're making a sine wave with the 2035 then converting it with the class D amp back to a pulse stream. The 2110 driver doesn't need a high power input to drive the IGBT transistors as far as I can see.
Instead of converting back and forth maybe you might want to look into just developing a simulated sine wave to drive the 2110's. I can  run you out a small microprocessor that I programed to do that.
Give me a call or let me know.
RobD
« Last Edit: March 08, 2004, 10:16:06 AM by RobD »
ibedonc
« Reply #2 on: March 08, 2004, 12:00:07 PM »
the 2035 is the 60hz sine , the LM4651 is a CLASS D amp chip and it's output is a PWM
but I do not think I will use the LM4651 , I have working a LM555 ramp gen. -->>  TL082 --> LM339 PWM circuit , I will have a schematic soon, was working on it last nite . Using the LT CLASS D amp schematic as a ref.
http://www.crestaudio.com/media/pdf/lt_schematic.pdf
« Last Edit: March 08, 2004, 12:00:07 PM by ibedonc »
ibedonc
« Reply #3 on: March 16, 2004, 01:02:08 PM »
ok , I am not using the LM4651 , using TL082 op-amps , they are a lot cheaper
« Last Edit: March 16, 2004, 01:02:08 PM by ibedonc »
