Author Topic: Fun new webpage  (Read 5105 times)
DanB
    • otherpower.com
Fun new webpage
« on: June 25, 2004, 09:14:27 AM »
Seems like every few days there is a new wind turbine that pops up here.  I think it'd be fun to create a "gallery" of completed (or near completed), homebrew wind turbines.  If anyone's willing to post a reply to this, along with a picture of a homebrew machine or two (or more) and a bit of detail about it, I'd like to make a big webpage that features them - and I can include names and links...and information about it or not - that'd be up to you, even just a picture would be fun.
So if you have a picture of a machine you, or someone you know built and don't mind my putting it on a webpage on otherpower.com - post it down below in a reply!  Could be a fun collection of machines.
« Last Edit: June 25, 2004, 09:14:27 AM by (unknown) »
Re: Fun new webpage
« Reply #1 on: June 25, 2004, 06:48:58 PM »
  You can post my little downwind turbine... 400 watts in a 35 mph wind using ceramic magnets... 42" 6 blade prop
  That "was" a fun little turbine.  I took it down this week to be re-used in another project.
Have Fun
« Last Edit: June 25, 2004, 06:48:58 PM by windstuffnow »
Re: Fun new webpage
« Reply #2 on: June 26, 2004, 10:08:51 AM »
Not quite finished yet but I'll throw mine in there.
And a link to the construction details which will be updated as I get more accomplished.
http://66.140.203.100/gallery/album36
« Last Edit: June 26, 2004, 10:08:51 AM by wooferhound »
MelTx
Re: Fun new webpage
« Reply #3 on: June 26, 2004, 04:27:32 PM »
This is my best genny so far,made from a ceiling fan.It does 60 open volt or 13.7 hooked to battery bank.Not many amps yet,Im still working on a better one.
                             Franknbuger
« Last Edit: June 26, 2004, 04:27:32 PM by MelTx »
Putte
Re: Fun new webpage
« Reply #4 on: June 27, 2004, 04:51:46 AM »
Nice to see them all in one place :)
6 blade 2.0 meters and built on a converted 16 pole asynchron motor.
Output is some 1000watts 3 phase and i used it for heat in a series resonant circuit with capacitors and light bulbs.
3 Blade 1.7 meters build on a servo motor i did get 2 for free. The "generator" is a bit to small, but for free its ok :)
Output is some 350 watts and i used it for chargin 24 volt batteries.
Putte from Sweden :)
« Last Edit: June 27, 2004, 04:51:46 AM by Putte »
billf
Re: Fun new webpage
« Reply #5 on: June 27, 2004, 09:27:01 PM »
They all look great.
Here's mine...8' prop-6 coils/12awg@150 turns-8 neos per rotor-dual rotor.
« Last Edit: June 27, 2004, 09:27:01 PM by billf »
Re: Fun new webpage
« Reply #6 on: June 28, 2004, 01:01:31 PM »
just another ceramic powered alt...
lights up 4 headlights with ease..using a electric drill..
but when i tried it with my prop it needed a strong wind just to light
up one headlight..so i added a second prop[4 blades] somewhat better output
but nothing that equaled the output using the electric drill..
so now i see why neo's are used...more power output at a slow speed !!!!!!!!!!!
the alt was made from a old MAYTAG motor[4 main coils 4 start up coils]
1/3 hp---think it was made in the 40s...
« Last Edit: June 28, 2004, 01:01:31 PM by hiker »
Re: Fun new webpage
« Reply #7 on: June 28, 2004, 02:48:11 PM »
this little alt works fine with ceramic mags--its a  old singer 1/4 hp motor--6 pole.
all coils in siries--blows out a 6-8 volt taillight just turning by hand..
lights up a 12v headlight but not as bright as the old maytag alt..
works better at a slow rpm--than the maytag--but lower amps..
puts out more power at a lower rpm due to the six coils instead of only four coils..
but less amps than the maytag--maytag has bigger coils-larger wire size...
« Last Edit: June 28, 2004, 02:48:11 PM by hiker »
Re: Fun new webpage
« Reply #8 on: June 28, 2004, 02:54:34 PM »
hello ED..
  whats the spec's on that motor ??
  does that six blade setup turn faster than a single blade prop or just more tork..
« Last Edit: June 28, 2004, 02:54:34 PM by hiker »
Re: Fun new webpage
« Reply #9 on: June 28, 2004, 10:27:33 PM »
  Hello Wild in Alaska,
    Its not a motor, its a scratch built alternator.   You can see the building of it at http://www.windstuffnow.com/main/test_page.htm .  Quite basic with the exception of all the electronics.  It did a mighty fine job for 3 years and still works great!  I took it down to rebuild it into another project.  The blades were designed to run at around a TSR of 4 and yes the 6 blades give it a bit more torque at start up.   Probably makes it a bit more inefficient in higher winds though.
Have Fun
« Last Edit: June 28, 2004, 10:27:33 PM by windstuffnow »
booner
Re: Fun new webpage
« Reply #10 on: June 29, 2004, 11:12:33 AM »
Hi All this is my first project what you think?? Its a 3 phase 9 coils 140 turns of 24 awg wire 12 neo`s.It stands about 5 ft tall about 20" wide made out of plywood and guttering for the blades.
« Last Edit: June 29, 2004, 11:12:33 AM by booner »
Re: Fun new webpage
« Reply #11 on: June 30, 2004, 12:24:53 PM »
whats the volts amps output???
« Last Edit: June 30, 2004, 12:24:53 PM by hiker »
Re: Fun new webpage
« Reply #12 on: June 30, 2004, 12:33:41 PM »
they do put out some volts --but no amps--great for L.E.D.s--try some jumbo L.E.D.s-
and put on a light show--mine lights up a whole string of L.E.D.s at the slightest touch--just jiggle the darn thing and it lights up--hey that works for me to....
« Last Edit: June 30, 2004, 12:33:41 PM by hiker »
booner
Re: Fun new webpage
« Reply #13 on: June 30, 2004, 01:05:19 PM »
Hi Its put out nearly an Amp at the minute its only been up and running about a 4 days and i have not had any good winds at the mo!!.
« Last Edit: June 30, 2004, 01:05:19 PM by booner »
Re: Fun new webpage
« Reply #14 on: June 30, 2004, 02:58:23 PM »
old maytag alt with extra blade...
my old 1916 motor--runs all day on that tank of gas.
should work great with one of my motor to alt conversions..
« Last Edit: June 30, 2004, 02:58:23 PM by hiker »
Re: Fun new webpage
« Reply #15 on: June 30, 2004, 03:00:02 PM »
1916 motor..
« Last Edit: June 30, 2004, 03:00:02 PM by hiker »
Re: Fun new webpage
« Reply #16 on: June 30, 2004, 03:11:19 PM »
if you live in the cave junction area [OREGON]
MY DAD HAS SOME REBUILT ENGINES FOR SALE..
 email me for phone number...
« Last Edit: June 30, 2004, 03:11:19 PM by hiker »
Re: Fun new webpage
« Reply #17 on: June 30, 2004, 04:00:37 PM »
 hello ED..               so whats it take to make a dowwind mill---just turn the prop around and take off the TAIL ??
« Last Edit: June 30, 2004, 04:00:37 PM by hiker »
edy252
Re: Fun new webpage
« Reply #18 on: July 01, 2004, 04:11:33 AM »
what's ur power rated output?
« Last Edit: July 01, 2004, 04:11:33 AM by edy252 »
Re: Fun new webpage
« Reply #19 on: July 01, 2004, 07:33:44 AM »
  Thats pretty much it for the basics.  You do need to make sure the pole is perfectly level and the distance the blades are away from the pole provides the blades with enough energy to rotate the unit when its not running.  I had to add a bearing to get it to move a little quicker to start in low winds.  Other than that its pretty straight forward.
Have Fun
« Last Edit: July 01, 2004, 07:33:44 AM by windstuffnow »
billf
Re: Fun new webpage
« Reply #20 on: July 01, 2004, 08:26:03 PM »
I've seen it go over 60 amps @16vdc while furling in 25 to 28 mph wind speeds.
« Last Edit: July 01, 2004, 08:26:03 PM by billf »
Virgis
Re: Fun new webpage
« Reply #21 on: July 02, 2004, 04:16:31 AM »
It is WK-5 from Lithuania.
We are using rewounded car alternator. 160 V AC 2,6 A (one phase), 3 phase connected in star.
Prop 3.55 m dia.
Gear ratio 1:6.
Virgis and WIND KIDS
« Last Edit: July 02, 2004, 04:16:31 AM by Virgis »
iFred
Re: Fun new webpage
« Reply #22 on: July 03, 2004, 12:46:22 AM »
Hey Dan!
Great Idea! use any picture you want on my web site!
« Last Edit: July 03, 2004, 12:46:22 AM by iFred »
devoncloud
Re: Fun new webpage
« Reply #23 on: July 08, 2004, 10:04:06 PM »
I dont have any pictures of mine yet as it's not built, but I sure could send a ton of pictures on blades I have ruined so far !:)
devon
« Last Edit: July 08, 2004, 10:04:06 PM by devoncloud »
