Author Topic: SmartDrive alternator  (Read 2053 times)
commanda
« on: August 11, 2004, 02:13:24 AM »
Getting a headstart here so I don't have as much to put up later when I start testing.
These are the Fisher & Paykel parts I have purchased. I'm buying all new stuff so I have a known good starting point. These parts purchased in Australia. Prices are in Aussie dollars.
Item No.     Description                   Qty            Unit Price
  1. P      Kit Stator & clamp plates      1                91.93
  2. P      Rotor ferrite                  1                78.83
  3. P      Bearing 6005LLU                2                 9.94
  4. P      Lipseal                        1                 9.95
  5. P      Shaft                          1                60.00
  6.       Nut Rotor                      1                 5.41
  7.       Nut Bearing                    1                 3.39
freight                                                      13.63
total                                                       283.02 (plus gst 10%)
Still missing the part which the 2 bearings sit in, and bolts to the stator, called a spline. Should arrive in a day or 2.
I have no idea what model(s) these parts fit.
The stator has 42 coils, connected as a 3 winding star. The resistance of each is 6 ohms. One end of each coil is brought out to a spade terminal. The other end of each coil is also terminated in a smaller female spade terminal, with a 3 pronged metal link to join them together to form the neutral point. So it would be fairly trivial to rewire it to delta if one so desired.
The plan is to not rewire the stator. Transmission of power from the tower to the battery bank will be high voltage. 3 toroidal transformers will transform the voltage down to 12 volts to charge the batteries. Toroidals should be better than 90% efficient. I'm expecting somewhere between 300 watts & 1 kilowatt out of this generator. At 12 volts, the line resistance to move that much power any appreciable distance (efficiently) becomes ridiculously small. And expensive.
The toroidals I have chosen are 250 VA each. They have 2 primary windings of 120 volts, and 2 secondary windings of 9 volts each. It should be possible to choose a series or parallel connection setup to match the generator. Maybe even a change-over relay for light wind / heavy wind. I purchased these from Oatley electronics for $25.00 each. They are mounted in a 2 unit rack case, although the bottom of the rack case sags with the weight.
Image of toroid
Enough for now, photos tomorrow.
« Last Edit: August 11, 2004, 02:13:24 AM by (unknown) »
BruceDownunder
Re: SmartDrive alternator
« Reply #1 on: August 11, 2004, 03:40:12 PM »
Hi Amanda, I"ve played around with these for many years now -not much success,because of time to get it up and running --  but have bench tested them and have seen 300 watts ,before my drill got hot.(drill was hooked up to drive it).
Anyhow , if you go to my IRC photo album ,you will see the pic's of what I've done.
are you in Oz-if so ,call me on 07 55453513 and I'll tell you what I've done.
Bruce
« Last Edit: August 11, 2004, 03:40:12 PM by BruceDownunder »
commanda
« Reply #2 on: August 11, 2004, 03:49:00 PM »
How do I get to your IRC photo album?
« Last Edit: August 11, 2004, 03:49:00 PM by commanda »
kurt
    • website
« Reply #3 on: August 11, 2004, 06:00:23 PM »
"How do I get to your IRC photo album?"
the #otherpower irc photo gallery no longer exists  at this time. the #otherpower irc server itself is still avalable and can be reached the usual way..
« Last Edit: August 11, 2004, 06:00:23 PM by kurt »
RobT
« Reply #4 on: August 13, 2004, 04:14:09 AM »
Hey Bruce, by your phone number, you sound pretty close to home!  I'm out in Esk, NW of Ipswich... (I know, I know...)  Still have clean air out here so far, so long as the 'city folks' don't keep buying up the land!
It's nice to hear from someone in this part of the land! Rob T.
« Last Edit: August 13, 2004, 04:14:09 AM by RobT »
domwild
« Reply #5 on: August 28, 2004, 01:43:46 AM »
Looks like commanda, you and I are Aussies all working with Kiwi technology!
Dominic Wild
Orange Grove, WA
« Last Edit: August 28, 2004, 01:43:46 AM by domwild »
BruceDownunder
« Reply #6 on: April 17, 2005, 03:36:38 PM »
Hello Rob. yes ,I'm at Mt tamborine . 55453513. Call me if you are down in the area and want to chat and see my f&P stuff.
I've just looked at your Cct's -very nice - I'm not up to that so much ,but can cut and weld steel.
Give me acall
Bruce
« Last Edit: April 17, 2005, 03:36:38 PM by BruceDownunder »
Trivo
« Reply #7 on: April 18, 2005, 03:12:15 AM »
Hi dominic
glad to see i'm not the only one from perth, i'm in wanneroo and have seen a couple of people from down south
Trivo
« Last Edit: April 18, 2005, 03:12:15 AM by Trivo »
