Author Topic: Whete to find shunt regulator schematics???  (Read 1779 times)
amiklic1
« on: January 18, 2005, 11:32:31 PM »
Does anyone know some good site where I can find shunt regulator schematics?
« Last Edit: January 18, 2005, 11:32:31 PM by (unknown) »
Larsanderss
Re: Whete to find shunt regulator schematics???
« Reply #1 on: January 18, 2005, 05:51:40 PM »
Good evening
One is in the download section at Homepower. I have built one myself an have a PCB layout as a .bmp file.
Lars A
« Last Edit: January 18, 2005, 05:51:40 PM by Larsanderss »
« Reply #2 on: January 18, 2005, 07:10:03 PM »
  Here is the download site for a shunt regulator http://www.homepower.com/magazine/downloads_homebrews.cfm?search=shunt%20regulator
They work quite well!
Have Fun
« Last Edit: January 18, 2005, 07:10:03 PM by windstuffnow »
paulpic
« Reply #3 on: January 19, 2005, 03:50:46 AM »
heres a 24v volt version of shunt. regulator,http://www.otherpower.com/images/scimages/236/shuntregulator18_24V.gif
just connect up a high current solenoid to fet to switch your dump,the load can be endless depending solenoid rating,i use 100amp solenoid on 12v system.
« Last Edit: January 19, 2005, 03:50:46 AM by paulpic »
BT Humble
« Reply #4 on: January 19, 2005, 03:34:56 PM »
Bear in mind that so far as I know nobody has actually built the 24V version, that's just the schematic incorporating the changes that Amanda thought would be required.
(I haven't found the time to try it out, got too many irons in the fire just like everyone else...)
BTH
« Last Edit: January 19, 2005, 03:34:56 PM by BT Humble »
Opera House
« Reply #5 on: January 19, 2005, 05:06:07 PM »
PWM 12V basic shunt regulator design
Pin    SG3524, LM3524, LT3524 Regulating Pulse Width Monitors
1    Input -, 2K to common, 2K to reference pin 16
2    Input +,  voltage divider from monitored voltage, 5.1K to common,
     .1 uF cap to common,
    20K resistor in series with a 5K pot connected to 12V sense point
3    Oscillator output, NC
4    + Current sense short to common
5    - Current sense short to common
6    Timer resistor 10K to common
7    Timer capacitor .1 uF to common
8    Supply common
9    Compensation, 27K resistor and .1 uF capacitor in series to common
    Optional gain reduction, 100K to pin 1
10    Shutdown, NC
11    Emitter output #1, to FET #1 gate and 270 ohm resistor to common
12    Collector output #1, to supply voltage
13    Collector output #1, to supply voltage
14    Emitter output #2, to FET #2 gate and 270 ohm resistor to common
15    Supply voltage, 1000 uF to common
    keep below 18V with zener to protect fet gate
16    Output, +5V reference, 2K to pin1 (this gives a reference of 2.5V)
Sorry, no schematic.  I figure most of you gear heads can follow a wire list better than a schematic. Print out the block diagram and draw in the components.  This circuit operates at about 600 Hz to reduce turn on and turn off heating of the FET.  This transition heating can be as much as from the full current.  Two BUZ71 FETs are used and each one is on 0-47% of the time.  The drains can be tied together to operate a single load or run two individual loads.  The FETs are driven with just a pull down resistor.  Not an ideal way, but simple and acceptable at this frequency.   Frequency is determined by the components on pins 6 & 7.   A 5K pot in the sense voltage resistance divider gives an adjustment from about 12.5V to 15V.  The 100K feedback resistor gives a slower transition from 0% to 47% on for each FET of about 0.2V.   With these FETs, the circuit easily handles 10A.
A couple of millivolts isn't much to you guys but it can drive this circuit crazy.  Remember that the wire connections from the battery to the load create a voltage difference this circuit can measure.  Running a separate sense wire to the battery reduces that.  While not a finished design, this gives a starting point to experiment with.
« Last Edit: January 19, 2005, 05:06:07 PM by Opera House »
