Ok, so pretty simple.
Take a generic Russian Dynamo Flashlight, they operate by pumping a lever which turns a flywheel with 2 * 1/2" x 1/4" magnets on it.
I alwas wanted to convert a lightbulb into an emergancy charger/power source from this thing. I traveled for a very long time with them and they are absolutly indestructable. They even work 100% submersed in water!
So today, i tried soldering a wire to a burnt bulb. It worked for several minutes, giving about 3.1w and than after securing the wires properly i got 5.08w!
The solder didnt want to hold, probably for lack of flux; so i opened it up (yes they are even servicable! lol ) and soldered directly onto the coils output lines. I hollowed out a space between the two halves of the body and passed my wire through.
Somehow im not getting the same power that i did before but its probable shoddy soldering on my behalf.
My readings were:
5.94 vac
.532a
& 9.117vac
.558a
To get the higher readings i had to really giver 'er! I guess in an emergancy you do what you have to though. I realised though, thats almost enough to power a small fluro!
Why did i wait so long to do this? Because untill earlier this week i honestly didnt understand electricity (or remember anyways) enough to do the calculations and work. One small step forward.
I think about 3 or maybe 4 of these gennies could fit in a bike hub... for those interested.
