Author Topic: Some Data On Treadmill Motor  (Read 4772 times)
« on: March 23, 2005, 10:52:30 PM »
  After a couple of trial and errors I finally
got the treadmill motor working....
   .....Yes! That shiny chrome handle is actually
 a 1/2 socket screwed onto the side of the
lawnmower wheel with a lag bolt and some washers!
....and the lawnmower wheel was actually an
exercise wheel ...you know the kind with
handlebar grips on each side? ....($.25 at
Goodwill)
   The multigroove belt from a Toro snowthrower
... I would have used the multigroove pulley
instead of the lawnmower wheel ...but I mislaid
it somewhere...
   The ratio is about 5.5 to 1
You can see in the background, one of the two
 (was $17.96-now $3.00)Play&Ride 6 volt
batteries that I got from Walmart...about 2
years ago (the model that they were used in
were recalled because the charger got hot
enough to burn someone), they had 24 more,
but someone didn't think I needed all those
batteries.
   As you can see above, it's putting 10.06 volts into this 6 volt battery @ 330 rpm.
   At this rate of charge it was putting out
.46 amp...Oooowh!...almost 5 watts!
   BTW that rpm on the $1 calculator is what
I would get if I hook it up to the lawnmower
wheel and preprogram the calculator ( +5.5)
and turn the charger fast enough to charge
about 10 volts.
   All kind of thoughts cross my mind here
fun things like hooking the wheel to be driven
by the rear tire of a multispeed bike...I could
charge some batteries.
 ....or hook it up to a VAWT ...I can see now
that it doesn't take too much power at all.
    Well that's what I did today...just had
a barrel of fun...in spite of the ice and snow
and stuff!  Hey! It's Spring!
                   ( :>) Norm.
« Last Edit: March 23, 2005, 10:52:30 PM by (unknown) »
Re: Some Data On Treadmill Motor
« Reply #1 on: March 23, 2005, 04:17:24 PM »
Norm;
Pretty neat stuff and i must say I think you have the only one of its kind on the planet!
All you need now is some wire to make a Tesla coil, something to make a spark gap and you can literally ride the lightning when you attach that bike drive unit!
« Last Edit: March 23, 2005, 04:17:24 PM by TomW »
« Reply #2 on: March 23, 2005, 09:32:44 PM »
  Yeah 24 of those batteries would have driven
a bike at a pretty good clip!
  I might just round up 3 or 4 12 volt batteries
and see how it works!
             ( :>) Norm.
« Last Edit: March 23, 2005, 09:32:44 PM by Norm »
« Reply #3 on: March 24, 2005, 11:30:30 AM »
Hey Norm,
(I'm back with a total profit!)
What is the open voltage at 330rpm?
If you get a chance, hook it up to a 12v battery and see what it does.
I have a feeling it will still give you a 1/2 amp with about the same effort.
My little grey conversion acts about the same as this one did,
and it doesn't seem to care if the amps go into 6, 12, or 24 volts.
And with about the same effort.
I do not know why. Maybe it is so many turns in both of them?
And doesn't it look like a VAWT just waiting for blades?
« Last Edit: March 24, 2005, 11:30:30 AM by ghurd »
« Reply #4 on: March 24, 2005, 05:18:40 PM »
   Gotta get back out to the shed....had an
answer ( about 200 words touched the wrong button
and lost it all!
            so later....
                 ( :>) Norm.
« Last Edit: March 24, 2005, 05:18:40 PM by Norm »
« Reply #5 on: March 24, 2005, 10:23:35 PM »
   Glad to see your back G.
   The open voltage at 330 was about 14 I think.
   A funny thing happened when I first hooked it
up...I was so anxious cranked it over as fast as
I could...each time I got it up close to 20 open
voltage ...the display would go to a 1, tried it
a few times..each time I got it close to 20...
same thing ....1  , Oh No! Something's wrong with
the motor! Finally realized I had to turn the
dial to a higher voltage setting...turned it to
the 200 voltage setting and cranked it up to
600rpm and got about 26-28 open voltage ...whew!
what a relief!
   Ever do somethin' dumb like that?
...and about that VAWT, like I said one time before ...make an electric bike with this...
, a VAWT like a small merry-go-round ...put the
back wheel on the circular deck to charge it up.
             ( :>) Norm.
« Last Edit: March 24, 2005, 10:23:35 PM by Norm »
nvmike
« Reply #6 on: March 27, 2005, 05:38:01 PM »
I just received my PM treadmill motor.  Would like suggestions on a prop design.
Has anyone tried these PM motors with wind?
Thanks in advance.
« Last Edit: March 27, 2005, 05:38:01 PM by nvmike »
« Reply #7 on: March 28, 2005, 12:15:38 AM »
I've been following everything about these (I might even have found them first?).
They have a few problems.  Bearings (?), leaking flux, 5 ohm coils, etc.
It looks to me like a good start, at least for a beginner (like me).
Better than anything else I bought for a decent price.
But I have not seen them with blades... yet.
« Last Edit: March 28, 2005, 12:15:38 AM by ghurd »
nvmike
« Reply #8 on: April 03, 2005, 08:49:07 PM »
Put blades on my treadmill motor today, the pulley was left threaded, so have the blades turning CCW.  It seemed to turn well, no data yet,  need to run some wire up the pole, next weekend project.  Hope to add a magnet and reed switch so I can get the RPM.
« Last Edit: April 03, 2005, 08:49:07 PM by nvmike »
nvmike
« Reply #9 on: April 09, 2005, 06:52:41 PM »
I got some data today on PM treadmill motor.  Three, 3 ft radius blades, 6 in constant cord,  160 rpm in 6 mph wind, 6 volts dc no load.  If I figured right a TSR of 5.7.
Was expecting more output.  Or is this about what you should expect for this setup?
New to all this and would appreciate comments or suggestions.
PS made my RPM counter from calculator idea found on this board.  This is a great board.
« Last Edit: April 09, 2005, 06:52:41 PM by nvmike »
« Reply #10 on: April 11, 2005, 09:34:02 PM »
  Nvmike,
     Very interesting ...would like to see some
pics if you can, is yours the same treadmill motor that I have here? If what you have this direct drive to the prop....you really should consider like I have started to develop for this
treadmill motor...it's getting late...if you see
this ...reply and I'll give you more detail...OK?
              ( :>) Norm.
« Last Edit: April 11, 2005, 09:34:02 PM by Norm »
nvmike
« Reply #11 on: April 14, 2005, 01:01:42 PM »
Yes the same treadmill motor, direct drive, next I may try to speed it up with pulleys.  Soon as i get digital cam back from my son, i will post a pic.
« Last Edit: April 14, 2005, 01:01:42 PM by nvmike »
« Reply #12 on: April 14, 2005, 05:26:55 PM »
   You won't have to speed it up with pulleys
...If you had it set up the way I have it in the first
picture have your blades driving this lawnmower
wheel...this size wheel gives you a 5.5 to 1 ratio ...when your mill is spinning 100 rpm. the
genny will be going 550rpm .
    I'm thinking of doing it a slightly different
way...I'll show you a couple of pics in a few days
hopefully.
                     Have fun!
                     ( :>) Norm.
« Last Edit: April 14, 2005, 05:26:55 PM by Norm »
nvmike
« Reply #13 on: April 15, 2005, 09:55:43 PM »
Thank you Norm, keep me up to date.
« Last Edit: April 15, 2005, 09:55:43 PM by nvmike »
nvmike
« Reply #14 on: April 16, 2005, 06:30:29 PM »
Updatge on treadmill motor in the wind.  I changed from direct drive to 3.5 to 1.  7 in pulley on blades to about 2 in. on the motor,  (v-belt to the treadmill motor multigrove pulley, will redo this later). Getting 12 volts (open, no load) with 6 to 7 mph wind, and hit 23 volts with gust to 10. (not much wind here).
May try chain drive next, having some belt slipping problems now. Still using 4 ft radius blades , three with 6 in. conatact chord.  Better blades are in the future.
« Last Edit: April 16, 2005, 06:30:29 PM by nvmike »
« Reply #15 on: April 18, 2005, 06:49:51 AM »
  Use a lawnmower wheel just like I did...but
have the wheel directly connected to the blades:
 Have a stop on the arm so it is almost tight
enough to begin with.
 A little observation how the arm will swing and
this arrangement should work fine...I don't think
you should ever have belt slippage with this
cast-iron flywheel/pulley on the treadmill motor
only when you try using a different pulley...
even then if you put a steel disk with the new pulley as a flywheel ...a flat multigroove belt
should not slip...it doesn't on the alternator in
cars....
                     ( :>) Norm
Having a little trouble with
tendonitis in left shoulder
so slower going over here.
« Last Edit: April 18, 2005, 06:49:51 AM by Norm »
pedal power generator...
« Reply #16 on: February 22, 2009, 08:35:18 AM »
rear tire of bike goes against the outside part
of belt...proper tension of belt is adequate to
prevent slippage....not too much pressure against
the bike tire needed!
« Last Edit: February 22, 2009, 08:35:18 AM by Norm »
