Author Topic: Idea of having magnet float  (Read 1600 times)
Bearcracks
« on: October 15, 2005, 05:27:16 PM »
I had the idea of putting a bunch of magnets around a small ball, all having the same charge facing outwards, and putting it in a bowl lined with magnets with the same pole facing inward toward the ball.  Would this make the ball float? If not why?
« Last Edit: October 15, 2005, 05:27:16 PM by (unknown) »
nanotech
Re: Idea of having magnet float
« Reply #1 on: October 15, 2005, 02:27:27 PM »
It would probably work, but me personally am drooling at the corners of my mouth thinking about someone using magnets in such a way when I'm desperately trying to gather enough together to make more than a single phase 2 volt alternator!!  :p
« Last Edit: October 15, 2005, 02:27:27 PM by nanotech »
Chagrin
« Reply #2 on: October 16, 2005, 09:56:41 AM »
Magnetic levitation is by no means simple. I can only think of a single person that ever achieved a similar "toy" that could be reliably built.
« Last Edit: October 16, 2005, 09:56:41 AM by Chagrin »
DanB
    • otherpower.com
« Reply #3 on: October 16, 2005, 10:09:14 AM »
It's a bit off topic for this forum but I'll bite.
The answer is... no - it wont float.  It'll either fall out of the bowl, or it'll stick to the inside, depending on how strong your magnets are.
Why?
http://math.ucr.edu/home/baez/physics/General/Levitation/levitation.html
http://wondermagnet.com/newmaglev.html
« Last Edit: October 16, 2005, 10:09:14 AM by DanB »
pyrocasto
« Reply #4 on: October 16, 2005, 11:51:27 AM »
I've never done any experiments or whatnot with it, but I kinda figured it would work. I guess it wont, but I still dont completely understand why completely. :-|
« Last Edit: October 16, 2005, 11:51:27 AM by pyrocasto »
dalibor
« Reply #5 on: October 16, 2005, 12:50:32 PM »
try to find on the web about nikola tesla.
there is something similar in his museum here in belgrade.
« Last Edit: October 16, 2005, 12:50:32 PM by dalibor »
« Reply #6 on: October 17, 2005, 01:02:43 PM »
That is annoying:  A simple proof that no stable (including when stalled) bearing is possible using just magnets.  You can get some support.  But you can't keep it in place with magnets alone.
But you can use magnets to levitate something diamagnetic.  Diamagnetic materials are weak, but you can get strong diamagnetism from a superconductor, or a strong pseudo-diamagnetism from a normal conductor versus a moving/varying field (with eddy current losses in the latter).  So THAT's why we never see news of magnetic bearing designs being attempted unless they involve superconductors.
But you can get SOME control and support - just not six-degrees-of-freedom stability - from magnets alone.  And with gyroscopic forces to keep a magnet from flipping end-for-end you can make it stable as long as it keeps spinning.  Those imply you might be able to do something for a rotor that involves a mechanical bearing when stopped or turning slowly, then a "lift off" at speed.
So all is not lost.  B-)
« Last Edit: October 17, 2005, 01:02:43 PM by Ungrounded Lightning Rod »
maker of toys
« Reply #7 on: October 17, 2005, 01:19:45 PM »
look up maglev turbomolecular drag pump.  Mitsubishi makes some nice ones. . .
so do Leybold, Pfieffer, <sp?> Alcatel and a few others.  We like ours- practically no maintainence.  the levitation is provided by a powered solenoid, but no superconductors in sight.
And, of course, inductrak maglev, using halbach arrays; but that's a specical case using the motion of the magnet to induce a field.
« Last Edit: October 17, 2005, 01:19:45 PM by maker of toys »
