Author Topic: Synchronous Rectifier suits power switching applications  (Read 1472 times)
« on: January 13, 2006, 03:45:56 PM »
I was looking over some of my old posts , on another site, and came across an interesting diode.
this is a quote from the article
to create diode with same forward-drop characteristics as MOSFET, eliminating heat sinks. It is capable of blocking up to 24 V and has typical forward voltage drop of 0.1 V at forward current of 20 A."
the article
http://news.thomasnet.com/fullstory/459712
the company
http://www.onsemi.com/PowerSolutions/product.do?id=NIS6111
the part
http://www.onsemi.com/pub/Collateral/NIS6111-D.PDF
« Last Edit: January 13, 2006, 03:45:56 PM by (unknown) »
drdongle
Re: Synchronous Rectifier
« Reply #1 on: January 15, 2006, 02:43:49 PM »
Now if they will just come out with a 100 volt version....
« Last Edit: January 15, 2006, 02:43:49 PM by drdongle »
Re: Synchronous Rectifier suits power
« Reply #2 on: January 15, 2006, 03:51:18 PM »
If I remember correctly,
there was a way of wiring power MOSFets in such a way (gate to drain, or gate to source; can't remember which) which made it basically into a diode, but with a very low Vf.
It shouldn't be too hard to design a piece of electronics, that basically samples your incoming sinewave, and turns on and off (I think 4) the MOSFets (in a bridge?), to get pulsed DC. Haven't looked yet, but am pretty sure such circuit designs exists.
However, the question is, do the costs plus the added complexity weigh up against the benefits (1.5V less powerloss, at ?? A). There's more things that can go wrong with active rectifiers than with diode-bridges. I don't think I would bother with them (unless the design was very simple and reliable), but there may be applications where this may a better solution than your standard diode bridge.
I did have a look at powerful Schottky diodes (Vforward = .2-.3V, instead of the .7-.8V of Silicon diodes), but so far (in my 2000 Farnell catalog) haven't been able to find any. This may be a much simpler solution than active rectifiers, but with a bit more loss.
Just some ideas that come to mind.
Peter,
The Netherlands.
« Last Edit: January 15, 2006, 03:51:18 PM by dinges »
stop4stuff
« Reply #3 on: January 20, 2006, 02:56:15 AM »
'Rectifier Bridge Has No 2Vf drop!'
http://www.thetaeng.com/FETBridge.htm
« Last Edit: January 20, 2006, 02:56:15 AM by stop4stuff »
« Reply #4 on: January 30, 2006, 08:05:10 PM »
That looks similar to a circuit i was simulating last March
« Last Edit: January 30, 2006, 08:05:10 PM by willib »
