I did this in the Fall of 2005 and thought I'd share it. I know it's been done before but can't hurt to bring it up again. I put up a little webpage with my info and pics for you and posted here. Hope it helps someone.
http://www.michigan-horse.org/preheater/
Skipb aka behoof
I live in a small brick ranch on a crawl with LP hot water that costs just too darn much to run.
There are commercial systems out there that would have you cut a hole in your woodburner and install their system. Personally I don't want to put anything inside the firebox or stack for the obvious concern of creosote and the loss of usable burn capacity.
Once I had put some thought into this project I decided to make a system that would not be invasive on my burner and would be simple, fun and efficient.
To begin this project I first cut a piece of .16ga sheet steel the same shape as the side of my woodburner only 1" less all around. Then I took a measurement of 1" less than that on each side, added up the measure of the sides and cut a stick of 1" angle iron that long. I then laid the angle on the .16ga sheet with the open side of the angle facing out (as in pic preheat_4.jpg). I cut and bent the angle so that it forms a sort of dish on top of my .16ga sheet. I used my DC Welder to tack the angle iron in place but you could just as easily drill it and use 1/4" x 1/2" USS bolts and nuts, whichever is the most efficient method for you.
Next I drilled two7/16" OD holes at the bottom/back of the bottom angle iron. This is for the ends of the copper tubing to pass through. I drilled this size so that I could put a piece of neoprene HD tubing through the holes then pass my copper tubing through the neo-tubing, this is to avoid chaffing (as in pic preheat_3 or 4.jpg) of the copper tubing.
Now comes the fun part. you need to pass enough 1/4" copper tubing through one of the neo-tube to give yourself enough to work with when you plumb your pre-heater all together. The next step is one you'll probably want to ask a tolerant friend to help you with, I did it alone and wouldn't ever again LOL. What you do now is carefully start making coils of your 1/4" copper tubing inside the "bowl" of your angle iron. Just keep going round and round and filling as much of the 1" angle iron "bowl" as you can without having it pop up over the top edge of your angle. It can get a bit tedious but it can be done.
After I made 75 feet of copper tubing coils I ran the other end out of the second neo-tube and cut off the excess. Next I went to my local ACE Hardware and get 20# of Plaster of Paris. I mixed of the plaster and poured it into my angle iron "bowl" then took an extra piece of angle iron and leveled off the top. For saftey against my coils popping up out of my Plaster of Paris I put a piece of 3/4" plywood on top of it and weighed it down and let it sit for a couple of days.
For mounting your pre-heater coil to your stove I guess you could just drill holes and use washers and stove cement but I chose to weld 1 1/2" USS bolts directly to the stove and that way when I was working with my pre-heater it was just hanging on the side of the stove, I didn't have to support it.
Now that I have my pre-heater mounted on my stove I go to the water heater and remove the drain valve and fitting on the bottom of the water heater (mine is a Rheem 50gal with 3/4" pipe) I installed a pipe nipple and Tee and reinstalled the drain valve on the Tee. On the side of the Tee I installed my TACO Pump (you can get one off of Ebay for $80 or less) with the direction of flow toward the Stove Mounted Pre-Heater. On the outlet side of the TACO Pump I install a copper reducer to get me down to 1/4" copper tubing. (Note: you could just as easily use 1/2" hard copper tubing to plumb from your 1/4" soft copper Pre-Heater to your water heater if you have to run any distance, just be sure to insulate it)
I now go up on top of the water heater to the outlet copper pipe which is also 3/4" and install a 3/4" Tee in the 3/4" pipe between the Relief Valve and the hot water tank. Then I sweat on a 90' ell and the necessary brass to get me down to 1/4" copper pipe. ( Note: Again remember that you could just as easily use 1/2" copper hard tubing)
I now run 1/4"soft copper tubing wrapped with insulation from my copper tubing inlet and outlet on my woodburner pre-heater to the TACO Pump and to the line hot water inlet fitting at the top.
Next I mount my thermostat ( I used an AC Type ) approximatly 1 1/2' from the back of my woodburner, that way as the stove heats up it will signal the TACO Pump to kick in as soon as the thermostat reaches your upper setting.
Now you need to refill and bleed your lines and that's just about it.
I've added the pictures below to show basically how this is all done and a picture of the basic parts needed to accomplish building your own woodburning water pre-heater.
NO MORE HOT WATER BILL IN THE WOODBURNING SEASON !!!
(see notes at bottom of page)
<center>
Pre-heater mounted on woodstove copper not plumbed yet
<center>
Preheat mounted not plumbed
<center>
Preheat prior to mounting
<center>
Preheat showing Plater of Paris bed for copper tubing
<center>
Preheat 2nd view before install
<center>
Preheat Some of parts
<center>
Preheat installing on woodstove
<center>
Preheat pump I got on Ebay
My Parts List:
- 50' Soft Copper Tubing
- lbs. Plaster of Paris
.16ga Sheet Steel
- "x 1" Angle Iron ( length according to your stove size)
- 5/16" x 1 1/2" USS bolts
- 5/16" USS nuts
- TACO or other brand circulating pump
- Air Conditioning Type home thermostat
- 3/4" Pipe Tee
- 3/4" Pipe Nipple
- 3/4" Threaded to copper tube adapter
- 3/4" Tee
- 1/2" copper street Ell
Necessary brass fittings to reduce down to 1/4" soft copper
Misc. fittings to adapt to needed unions.
Of course your fittings and other misc. items will vary with stove and your added ideas to this project.
Note: I haven't had any issues with overheating and I ran my woodburner at full tilt for four hours with the pump unplugged. It showed no signs of having any issues.
One thing that might be a good idea and I may very well do this myself just as a saftey precaution is install a temp sensor on my water heater and wire in a high temp shut down. Like I said though, I'm sure I won't need it but just to be on the safe side and besides I love doing this energy saving stuff!
Another thing you could do depending on your needs is add a second unit as the pre-heater for your main water heater. I think this would mate very well using solar, bio or other forms of energy to preheat your water.
Skipb aka behoof
