Author Topic: 6.625" disc alt.  (Read 903 times)
6.625" disc alt.
« on: March 22, 2006, 05:03:18 AM »
Looks like the coils for the littel 6.625" dual rotor will be round. 2.5" diameter with slightly less then 1.5" hole to match the magnets. I wound 6 of these coils for the 8 magnets per rotor.
100 turns of #20 wire at .25" coil thickness. The 2.5" outer coil diameter is all I could make within the 8each of the 1.5" magnets glued to the 6.625" steel discs.
Might not be optimum but I think it will work?
I'll start the stator part tommorow.
« Last Edit: March 22, 2006, 05:03:18 AM by (unknown) »
Re: 6.625" disc alt.
« Reply #1 on: March 21, 2006, 10:07:05 PM »
PS the stator form is 8.5" diameter. Same fiberglass sheet build as my littel yellow dual rotor disc alt.
« Last Edit: March 21, 2006, 10:07:05 PM by Jerry »
spinner
« Reply #2 on: March 22, 2006, 06:27:41 AM »
jerry
looks like another interesting project for ya ( and all of us who follow your projects )!
thanx
spinner
« Last Edit: March 22, 2006, 06:27:41 AM by spinner »
