Author Topic: Don't you HATE it when  (Read 1368 times)
coldspot
« on: March 24, 2006, 05:50:11 PM »
I hate when I only find one
when we need two to work.
This is from a Bike that was
burned up some how and
was being parted out.
It had only the front forks so I'll never know
what it was to try to find
a match.
But the farm I was at had TONS of
stuff! :)
The farmer types here should know how easy
it is for them compaired to the "City" folks,
When it comes to having access to stuff and parts!
At least the son at the farm reconized what I had to
offer and will be a wind mill customer for me! :)
And he will also be a great source of parts n stuff!  :)
« Last Edit: March 24, 2006, 05:50:11 PM by (unknown) »
$0.02
nanotech
Re: Don't you HATE it when
« Reply #1 on: March 24, 2006, 11:33:35 AM »
Heh, I just noticed that I think we have exactly the same motherboard.....  :)
« Last Edit: March 24, 2006, 11:33:35 AM by nanotech »
« Reply #2 on: March 24, 2006, 12:09:41 PM »
it must have been from a small bike , i have two sets , one i got from ebay , the other i found locally
the set from ebay is 10.850" dia , off of a 650 suzuki i think it was, the other is 11.6" dia.
ive found most bike front disk brakes have the same inner dia , but different bolt patterns , some six , some five..
« Last Edit: March 24, 2006, 12:09:41 PM by willib »
drdongle
« Reply #3 on: March 24, 2006, 04:19:16 PM »
Go to some bike shops they may be able to hook you up with another one.
« Last Edit: March 24, 2006, 04:19:16 PM by drdongle »
coldspot
« Reply #4 on: March 25, 2006, 06:41:42 AM »
"K8NS PRO"
Love the 4 IDE slots, (8 things)
Not to mention the Serial ATA, (Only two things so far)
AMD 3000 64Bit
2 Gigs of RAM
Liquid Cooled
TEC + Water block on Video card
Homemade RAM Water Blocks
NOT MY SURFER
PS: Stayed up all night working on it, (last night)
Still putting it back together from the move into
girl friends place. (Darn wind mills have kept me
away from it) LOL
« Last Edit: March 25, 2006, 06:41:42 AM by coldspot »
$0.02
maker of toys
« Reply #5 on: March 26, 2006, 12:09:10 AM »
looks like the front disk off a Virago. (yamaha 750 cruiser style)  they used that disk on a bunch of stuff from about 1980 to about 1992. I think I have one lying around someplace;  It's yours for the cost of UPS. (steelnomad2002 at yahoo) Somewhere on the inner part of the disk you will likely find a part number. . . . you may have to scrape some paint to read it.
Yamaha might still have some of those NOS;  let your fingers do the walking?
most large cities have cycle salvage places; there are a few on the 'net.
 The steel they use for those disks is a corrosion resistant alloy, and may not do well for completing the magnetic circuit. I'd set up a comparison test (with, say 1014(?) steel AKA hardware store hot rolled plate) before I got to mixing resin. your milage may vary.
(in the useless trivia catagory:  the Virago uses the frame as part of the air-intake path, and oil from the PCV system can build up and ignite in a backfire, like if (say) you got the plug wires on wrong.  that might explain the "burned up" part.  Nope. . . never seen that happen.  <whistles off key>)
« Last Edit: March 26, 2006, 12:09:10 AM by maker of toys »
coldspot
« Reply #6 on: March 27, 2006, 06:39:29 PM »
maker of toys
Thanks for the offer!!!
This disc brake rotor
Wide = 10 5/8th"
Across inside of brake pad flat area
is 6 5/8th"
height
3/4"
THANKS
« Last Edit: March 27, 2006, 06:39:29 PM by coldspot »
$0.02
coldspot
« Reply #7 on: March 27, 2006, 06:40:25 PM »
OOP's
Forgot
I wire wheel brushed it off
No part number.
« Last Edit: March 27, 2006, 06:40:25 PM by coldspot »
$0.02
maker of toys
« Reply #8 on: March 29, 2006, 10:33:50 PM »
Huh.  I'd have figured a part number would be on there somewhere. Just about everything else on those bikes has a number stamped on it. . . (except the o-rings.  Grrrr)
the sizes sound about right for what I remember.
I won't be able to dig for the disk until this weekend at the earliest, as it's two hours each way from where I am at the moment. . . so don't dispair if I'm a little slow getting back to you.
(I might send my dad down to the shop with a tape measure?)
Anyrate, I havn't forgotten you; I'm just packed up with work and other spare time activities.
-Dan
« Last Edit: March 29, 2006, 10:33:50 PM by maker of toys »
coldspot
« Reply #9 on: March 30, 2006, 03:41:07 PM »
makeroftoys-
" I havn't forgotten you; I'm just packed up with work and other spare time activities."
Don't go out of your way at all.
I'm in NO hurry, And have nothing else to go with it but idea's.
So don't even get to it till when ever, month, season.
But, THANK YOU for the offer.
PS: Have A GREAT Day/Night, WEEKEND !!!!!!
« Last Edit: March 30, 2006, 03:41:07 PM by coldspot »
$0.02
maker of toys
« Reply #10 on: April 16, 2006, 03:18:51 PM »
well, in case  Coldspot is still monitoring this thread:
I checked the disk I have.  it's 300 mm (ca. 11 7/8") in diameter, with an inner dia of about 8"
so much for my calibrated memory, eh?
-Dan
« Last Edit: April 16, 2006, 03:18:51 PM by maker of toys »
