Author Topic: F&P down wind ready for trower.  (Read 1337 times)
« on: April 18, 2006, 04:02:09 AM »
Heres a few pix. Yellow spacers alow down wires to fit between alt base and bearing mount.
Now on to the tower.
« Last Edit: April 18, 2006, 04:02:09 AM by (unknown) »
RP
Re: F&P down wind ready for trower.
« Reply #1 on: April 17, 2006, 10:20:19 PM »
Jerry,
Will you be covering the downwind side of the F&P unit?  If not, I'm worried about the exposed wiring around the rectifiers.  Could you hose it down with some clear poyurethane or something?
« Last Edit: April 17, 2006, 10:20:19 PM by RP »
« Reply #2 on: April 17, 2006, 10:34:55 PM »
Hi RP
Yes I've allready done that. Acctully did 3 coats. Its clear so you can't see it.
Should be able to hose it down. I'll know soon enough, hope to have it up on the tower in a day or 2. I'm in Oregon and we're still getting plenty O rain.
The down wind thing will be fun to watch? You don't have to worry about the blades hitting the mast. With that bearing in yaws real easy.
« Last Edit: April 17, 2006, 10:34:55 PM by Jerry »
« Reply #3 on: April 18, 2006, 06:50:29 AM »
Jerry;
Glad to see you doing something with that F&P! I don't think I would have got far.
Sure wish you could get someone to help you get on irc so we could pick your brain some.
« Last Edit: April 18, 2006, 06:50:29 AM by TomW »
« Reply #4 on: April 18, 2006, 07:57:16 AM »
Three coats.  What did you go with?
« Last Edit: April 18, 2006, 07:57:16 AM by ghurd »
« Reply #5 on: April 18, 2006, 09:00:45 AM »
Hi G.
I used Rust-Oleum  American Accents clear top coat. It says Non-Yellowing and UV resistant.
I know its not heat resistant but I don't think there will be any heat in this alt.
I'm still in a search mode for that red heat proof motor/coil varnish.
« Last Edit: April 18, 2006, 09:00:45 AM by Jerry »
« Reply #6 on: April 18, 2006, 09:10:22 AM »
Hi TomW.
It took along time  HU. Well thats the way it is here. Its like I tell some folks around here. A 2 day project only takes 6 months here.
Allways losts of busy going on.
Thanks for the invite. I've looked at the IRC acouple times but was intimidated and couldnot negociate getting in. You know computers and me don't get along.
I read the requierments of what I needed to do and the software or hardware I needed but that stuff all sounds like a forign language to me. It might as well been in chineez.
Also I only have one finger that types so it would be hard to keep up in real time?
I do thank you for the invite. Its hard to teach an old dog new tricks. I may still get there some day? All I need is time and a coach.
Thanks again Tom.
« Last Edit: April 18, 2006, 09:10:22 AM by Jerry »
domwild
« Reply #7 on: April 19, 2006, 05:43:22 PM »
Jerry,
Thanks for photos. I hope the washing machine bearing at the prop side will hold up. The one at the F&P side is strong enough.
Anyway, without trying we shall never know.
« Last Edit: April 19, 2006, 05:43:22 PM by domwild »
domwild
« Reply #8 on: April 19, 2006, 05:47:56 PM »
Jerry,
Tell us how you are going to untwist your wires. Great job! Might try downwind too.
Jerry blades with extenders!
« Last Edit: April 19, 2006, 05:47:56 PM by domwild »
« Reply #9 on: April 19, 2006, 10:12:47 PM »
At one time I had 14 wind gennys on my store roof. Some had been up there 5 years. I fly 7 gennys at home same kinda time frame. All my wind gennys have wires going down the center of the mast. I've never had a wire twist problem.
It works for me.
« Last Edit: April 19, 2006, 10:12:47 PM by Jerry »
