Author Topic: Stator storie  (Read 3072 times)
SmoggyTurnip
Stator storie
« on: April 26, 2006, 05:00:54 PM »
I built a simple coil winder and mold
and made a stator. It has 21 coils, 18 gauge wire,
196 turns each. Inside hole was 1" by 2" - the
same size as my magnets.
« Last Edit: April 26, 2006, 05:00:54 PM by (unknown) »
SmoggyTurnip
Re: Stator storie
« Reply #1 on: April 26, 2006, 11:02:36 AM »
 When I went to connected
all of the coils together I thought it would be easier
to make the connections on the outside of the
coils rather than on the inside because there
was a lot more room there.  I forgot that that is where
the holes were to be drilled to mount the thing to
the stator mounting bracket.  I used baby powder
with my resin so the stator was only semi-transparent.
By putting a bright light behind the stator I could see
most of the wires and I tried rotating the stator mount
bracket around to find a position where I could drill
holes without cutting through a wire.  The first hole
cut 3 wires - the second cut 2 wires - the third cut 3.
Using the light I could see that there was no place
that I could drill a hole without cutting wires. I tried
using a jigsaw to cut along side the cut wires to dig
them out and join them back up again.  This worked
but also cut more wires. After about 8 hours I had
all the wires reconnected, soldered and the holes
patched up with resin.  I decided it would rather
start over than continue with that frustrating process.
I was able to test that stator by mounting it with the
3 holes that I did have - It gave me 168 volts at 198rpm.
I didn't like making the connections from one coil to
The next so I built a new coil winder.
« Last Edit: April 26, 2006, 11:02:36 AM by SmoggyTurnip »
SmoggyTurnip
Re: Stator storie
« Reply #2 on: April 26, 2006, 11:06:27 AM »
This way I could wind all 7 coils for each phase
From 1 continous piece of wire and not have to
make any solder connections.  I also found counting
196 turns for each coil a bit tedious so I added this
simple turn counter.
« Last Edit: April 26, 2006, 11:06:27 AM by SmoggyTurnip »
SmoggyTurnip
Re: Stator storie
« Reply #3 on: April 26, 2006, 11:08:19 AM »
 It worked good but I left a bit too much
wire between coils.
« Last Edit: April 26, 2006, 11:08:19 AM by SmoggyTurnip »
SmoggyTurnip
Re: Stator storie
« Reply #4 on: April 26, 2006, 11:12:08 AM »
When I poured the first stator I used duct tape
for the mold release because that is what I used
when I did my rotors and it worked great.  But
I used epoxy resin on my rotors and it didn't
heat up much.  I used polyester resin on my stator
and the heat it produced caused the duct tape to
wrinkle up a bit so I didn't get a very smooth finish,
It would be ok I think - just didn't look so great.
I wanted to use a different material on my second
try so I tested out this flooring material that I had
lying around.  I poured some resin on a piece of
it, let it harden, and it came off easy and smooth and
I decided I would use it to make my mold.  I still
used the duct tape for the center part of the mold.
« Last Edit: April 26, 2006, 11:12:08 AM by SmoggyTurnip »
SmoggyTurnip
Re: Stator storie
« Reply #5 on: April 26, 2006, 11:13:28 AM »
I put 21 bolts through the back of the mold, .25" diameter,
one in the center of each coil.  I put a bit of vasilene on each
bolt so they would be easy to remove.  This worked great on
my first stator so I wasn't worried about it at all.  They didn't
leak at all and were easy to remove.  On my first mold I used
a 24 inch diameter circle cut out of MDF for a cover but I was
unhappy with it because some resin got between it and the
center part of the mold and it kept the cover from going all
the way down making the stator thicker than I wanted. So this
time I cut out a ring - it worked much better.
« Last Edit: April 26, 2006, 11:13:28 AM by SmoggyTurnip »
SmoggyTurnip
Re: Stator storie
« Reply #6 on: April 26, 2006, 11:14:45 AM »
On the other side of the MDF ring I put the flooring
Material so that it wouldn't stick to the material.
I poured the resin at 8:00pm and sat sown and had
a cup of coffee and was happy to finally have the stator
in the mold - what could go wrong now I thought.
I went to check on it at 10:00pm because the first stator
took about 2 hours to harden. Hmmm - this wasn't hard
yet.  Well I thought about the first one and it seemed like
it did all of its hardening in the last 20 minutes - maybe
this one is going to take off any minute now.  While I was
standing around waiting I thought I would put the meter
on the terminals again just to make sure everything was
ok.  First phase OK, second phase OK, Third phase OPEN
CIRCUIT - arrrrg! What happened???  Each phase is one
continous wire so it must just be disconnected from the
stainless steel bolt that is attached to the end of the wire.
Thinking I might only have a half hour or so I remover
the 21 nuts and removed the top of the mold.  I checked
the connection to the bolt and it was OK.  What now??
I took the top piece of fiberglass off and dug around inside
following the wires for that  phase from one coil to the next
and eventually came to a break in the wire.  When I put the
21 bolts through the back of the mold I accedently put a short
one through - when I went to tighten the cover down I noticed
the short bolt - pushed it through the mold and replaced it with
a longer one.  There was a wire pressing against the side
of that bolt and it moved into position to be cut when I
put the new bolt in.  I stripped the wires and connected them
together, bolted the cover back down, and went to bed.
I got up at 6:00 am and went to check on the mold - it didn't
harden at all - "whats wrong with this thing???  Maybe it's
too cold here in the basement, but I did the first mold in the
basement." . I took the mold upstairs and turned the thermostat
up to 75 degrees and left for work.  When I came home it
was hard.  Another hurdle over.  I started taking the mold apart,
-    looking good.
« Last Edit: April 26, 2006, 11:14:45 AM by SmoggyTurnip »
SmoggyTurnip
Re: Stator storie
« Reply #7 on: April 26, 2006, 11:16:25 AM »
When I took the last part of the mold off this is what I found.
« Last Edit: April 26, 2006, 11:16:25 AM by SmoggyTurnip »
SmoggyTurnip
Re: Stator storie
« Reply #8 on: April 26, 2006, 11:17:24 AM »
It seems that when I took the cover off to fix the open
circuit one of the washers fell off the cover and went
into the resin. I took my dremil roto tool and carefully
made a small cut around the the edge of the washer and
was able to pull it out .  I drilled the mounting holes and
used my meter to check the phases again and all is OK.
I have not tested this stator yet but I expect it to work -
after all, what could go wrong now?
« Last Edit: April 26, 2006, 11:17:24 AM by SmoggyTurnip »
Re: Stator storie
« Reply #9 on: April 26, 2006, 12:03:22 PM »
smoggy , those coil look good nice and dense.  i realy like your multi coil jig. i tried to go that way but couldn't get the retaining wire to slip under the inside coils . looks like you found away. i'll give it another try.  i used a 5.5 to one gearbox from an electric lawnmower and an electric drill to motor up my winder. try that next.also a foot swich is good to keep your hands free.
 i poured a stator two weeks ago. turned out great.
last week i tried again but just as i had poured in about half the resin a customer came in wanting a business card. no sweat, caus' the first stator had taken over night to kick.  when i got back to it i discovered the first mixture was already getting stiff. yikes!! mixed the rest and slamed the lid down quick. i didn't realize it was about ten deg. warmer outside.  my 3/8" thick stator is i/2" thick !
« Last Edit: April 26, 2006, 12:03:22 PM by electrondady1 »
SmoggyTurnip
Re: Stator storie
« Reply #10 on: April 26, 2006, 12:21:01 PM »
Actually I did use a sewing machine motor
and geared sown about 16 to 1 with a foot
switch at first, I found it too dificult
to control so I took it off.  Even with
200 turns it doesn't seem to take very long
to wind a coil.  Maybe 3 turns per second.
It all adds up though with 21 coils and 200
turns each thats 4200 turns.  It took about
  1. hour to wind each phase.  I took me about
  2. hours to make all the connections on the
first stator so I think the ganged coil
winder was worth the effort.
Someone told me that it always takes twice
as long as you think to do something - unless
it looks easy - in that case it takes 3 times
as long. I have to agree.
« Last Edit: April 26, 2006, 12:21:01 PM by SmoggyTurnip »
  • Country: aq
  • Village idiot
Re: Stator storie
« Reply #11 on: April 26, 2006, 12:31:02 PM »
Grit and determination, thats what I like to see....in it to the bitter end. I have some empathy here with you and your trials and tribulations :-).
4200 turns..... powerful lot of wire there.
Great result, ripping yarn and keep it up...........oztules
« Last Edit: April 26, 2006, 12:31:02 PM by oztules »
DanB
    • otherpower.com
Re: Stator storie
« Reply #12 on: April 26, 2006, 12:31:08 PM »
I like the idea of winding a whole phase on a long coil winder so you dont have to make connections between the coils....  might try that.
« Last Edit: April 26, 2006, 12:31:08 PM by DanB »
Re: Stator storie
« Reply #13 on: April 26, 2006, 01:18:34 PM »
Yes, it's an original idea. Looks very good.
Only problem I have with it is that I usually tie some string around my coils before I take them out of the mould, so they'll stay in shape. I normally use 4 pieces of string per coil. Seems hard/impossible with his method.
But you get rid of the job that I dread most: cleaning all the connections and soldering them together. For single-wire coils it's doable, but for 2-in-hand coils... It's one of the reasons I stay away from 2-in-hand winding, for as long as I can. His method becomes double as attractive for 2 (or even 3?) in hand winding, I think.
Peter.
« Last Edit: April 26, 2006, 01:18:34 PM by dinges »
RP
Re: Stator storie
« Reply #14 on: April 26, 2006, 07:42:30 PM »
Can you identify the flooring material you used?  That seems like a nice method to get a smooth surface.
« Last Edit: April 26, 2006, 07:42:30 PM by RP »
powerbuoy
Re: Stator storie
« Reply #15 on: April 26, 2006, 08:52:31 PM »
Concerning then soldering ... we used to take a blow torch to get rid of the insulation at the ends, then we used a welding tool ...don't know the brand but it had a carbon tip. The ends basically melted together in notime. Zaaaappp ....done, next, zaaapppp done next.
Powerbuoy
« Last Edit: April 26, 2006, 08:52:31 PM by powerbuoy »
Re: Stator storie
« Reply #16 on: April 27, 2006, 01:38:17 AM »
For a high voltage machine I would have slipped a piece of sleeving on the interconnections between coils. In the picture with the washer in it I think I see interphase links crossing coils in other phases. This is ok at low volts but it is not good practice for a high voltage winding. It will no doubt be ok but better to play safe.
With your continuous coil set up you would need to thread all the sleeves for one phase on to the wire at the start.
Nice work otherwise.
« Last Edit: April 27, 2006, 01:38:17 AM by Flux »
SmoggyTurnip
Re: Stator storie
« Reply #17 on: April 27, 2006, 07:15:56 AM »
I don't know exactly what it is called, around here
everyone calls it "click flooring" because of the
click it makes when you join two pieces together.
It is very popular these days as a cheap alternative
to hardwood in rec rooms etc..  The pieces connect
together verytight so the seam is almost imperceptable.
In the picture with the washer you can see the mark the
seam made but it look alot worse in the picture
because of the lighting.  A light sanding eliminated
the mark completly.
« Last Edit: April 27, 2006, 07:15:56 AM by SmoggyTurnip »
SmoggyTurnip
Re: Stator storie
« Reply #18 on: April 27, 2006, 10:29:21 AM »
When I built my new stator I decided to
change the dimensions of the coils. I made
the inside dimensions 1.75" by .75". I also
reduced the thickness from .59 inches to
.5 inches so I could get a tighter air gap.
 I made the number of turns 200instead of 196
 - just because its an even number.  My calculations
showed that this would give me about 10% more
voltage (cause I could reduce the air gap)
and 20% less resistance.  This may not
seem like much but a 10% increase in voltage
means a 20% increase in available power and
a 20% decrease in resistance means 25% more
power available (for a given rpm). I wasn't
worried about strength because the stator will
be attached with 21 bolts - that puts 2 bolts
on each side of every coil.
I calculated the resistance of  one phase for
my first stator to be 5.74 ohms and to my
surprise my meter measured it to be 5.7 ohms.
I calculated the resistance for my new stator
to be 4.49 ohms but also to my surprise it
measured 5.6 ohms.  I have the two stators side
by side and using the same meter measure the
resistance of each and I consistently get 5.7
for all phases on the first stator and 5.6 on the
second stator.  I realize that this is not an accurate
way to measure but could there be that much
difference?  I'm still scratching my head over this.
I put my new stator into the alternator last night
and did some testing.  The first thing I did was
spin it up by hand and then short out the terminals
with a knife and watch the sparks.  It actually welded
the knife to the terminals (not a strong weld but impressive).
next I shorted out the phases one at a time and turned
it by hand to feel the cogging just because it's fun.
When I had all three phases shorted out I could still
feel a small amount of cogging.  I didn't feel any
cogging on my first stator when I did this, so I walked
around and scratched my head for a while. It's a small
amount of cogging, just noticeable - maybe its because
I have a more powerful alternator now.
Next test - spin it up using a 5hp motor and check the
voltage.  157 volts at 198 rpm. Hmmm this is less than
my previous stator - more walking around and head
scratching.  Maybe it's my meter connections. I just
switched the meter from volts to ohms and it read 5.6
so that ruled that out.  Well let's check another phase.
Exactly the same thing.  My calculations must have been
wrong but I did them over and over I had confidence in
them.  Well let's check the third phase - 185 volts, now
that's more like it - it's 10% higher than the first stator.
Maybe one of my coils is upside down - but I know I
checked the orientation of all the coils carefully before
I poured the resin. And if one coil was upside down it
would  cancel out just one other coil giving me
5 out 7 coils or 132 volts.  It seemed that there was 6
out of 7 coils active.
I needed a way to test my coil orientation just to
make sure.  I read posts on this boars about people
connecting power supplies to the phases and using
a magnet to test this.  I didn't have any power supply,
I didn't even have a 9 volt battery.  All I could find
was an old AA battery that was in the junk drawer
for at least 2 years.  What the heck - I'll hook it up
and see what happens.  To my surprise I was able to
detect the magnetic field with a neo magnet - it was
weak but I could feel it.  I had 4 extra magnets so
I stacked them up and now it was very easy to detect.
It turned out that all the coils had the proper orientation
but 2 coils were in the wrong place.  Instead of going
ABCABCABC... they went ABCACBABCABC....
I could not believe that I could make a mistake like that.
 I really need to learn some new curse words because I
am getting tired of all the ones I've been using over the
last week.
Luckily the two coils that needed to be swapped were the
first in the each of the phases so they each had a wire
going to the steel bolts that I used for terminals.  I would
not have to swap these wires I could just swap the wires
that connected to load.  The swap the other wires would
require more brain surgery.  After successfully removing
the first tumor (washer), and having gained some experience
on nerve reconnection on my first stator I felt like I was
now qualified to attempt this operation.  Using a strong halogen
lamp behind the stator for x-rays and a dermal tool for a scalpel
I was able to carefully cut around the wires I needed without
damaging any others.  I was only able to get about 1" of each
wire so they were difficult to strip and I had to add a jumper
to each wire in order to get the required length to reconnect
them, but I did manage to get the job done. I checked the
resistance of each phase and they are all reading 5.6 ohms
again so everything looks OK.  By now it was 1:00 am and
I was tired so I didn't check the magnetic fields with the
battery and magnets but I'm sure I thought of every thing
so what could go wrong now?
« Last Edit: April 27, 2006, 10:29:21 AM by SmoggyTurnip »
SmoggyTurnip
Re: Stator storie
« Reply #19 on: April 27, 2006, 10:39:43 AM »
Actually it's easy to get the string
around the coils.  If you look close
pictures you can see that I used magnet
wire instead of string.  The wood that
seperates the coils are 1/2 in thick
so i Just bent the wire into a U shape
and set it in the slots.  When one coil
is done just connect the ends.  I only
used 2 but 4 would work just the same.
« Last Edit: April 27, 2006, 10:39:43 AM by SmoggyTurnip »
SmoggyTurnip
Re: Stator storie
« Reply #20 on: April 28, 2006, 07:43:20 AM »
Last night I mixed up some resin and patched
up the holes that were made during the repair.
Tested the placement and orientation of all
coils using the magnet and battery. All seems
OK.  Was not able to put the stator into the
alternator yet.  Resin hardened OK.
« Last Edit: April 28, 2006, 07:43:20 AM by SmoggyTurnip »
Re: Stator storie
« Reply #21 on: April 28, 2006, 11:55:08 AM »
wow smoggy !!
you have my sympathy
but i'm glad it is all ok now..
« Last Edit: April 28, 2006, 11:55:08 AM by willib »
SmoggyTurnip
SmoggyTurnip makes electricity
« Reply #22 on: May 03, 2006, 06:21:20 AM »
I got my stator problems all resolved.
This is what my alternator looks like now.
I connected 2 25 watt bulbs, a 60 watt bulb,
and a halogen light ( I don't know how many watts)
to the machine and spun it up by hand and this
is what happened:
It's not a very good pic because I was
turning the thing with my right hand and taking
the pic with my left hand.  All the lights came
on to full brightness - it was hard to turn but
I still could have turned it faster but did not
want to risk burning the bulbs out.
My first test was to connect just 3 25 watt bulbs
(110 volts each) and spin it by hand.  I was surprised
to see that after I stopped spinning it by hand that
the momentum of the rotors would keep the lights on
for about 20 more seconds (with the light gradually
getting dimmer of course).
Finally the laws of physics trump the laws of Murphy!
« Last Edit: May 03, 2006, 06:21:20 AM by SmoggyTurnip »
Re: SmoggyTurnip makes electricity
« Reply #23 on: May 03, 2006, 07:04:52 AM »
"Finally the laws of physics trump the laws of Murphy!"
That's not what happened at all!
Murphy has simply been busy with me.
Too busy to spend any time with you.
« Last Edit: May 03, 2006, 07:04:52 AM by ghurd »
SmoggyTurnip
« Reply #24 on: May 03, 2006, 07:21:22 AM »
Please try and keep him busy for a while.
« Last Edit: May 03, 2006, 07:21:22 AM by SmoggyTurnip »
