Author Topic: big black and flyin mags  (Read 2505 times)
« on: June 03, 2006, 09:52:02 AM »
rebuilt big black--8 and 6 ... 53 winds per coil #14plastic coated insulated wire[its what i had].
turned out a little heavy -and sence my little 7.5 alt takes care of my needs for the motorhome--i decided to try out big black on a exersize bike..
worked out great --with the low windings i didnt have to fight the resitance in the wire..disconnected the batt. from the motorhome and hooked up big black to the batt cables then turned on all the lights-plus i hooked up a extra 100 watt auto headlight.
no problem on doing that--close to 300 watts..real easy with just a 100watt headlight.
well i decided to go all out and hook up a 38volt aircraft landing light--it has two elements on it-400 watt and 1000 watt..hooked up the alt to the 400 watt element..
well --i was doing great getting close to 31 volts--pumping like crazy--
BOOMMMM.....mags go flying past my face at a terrific speed..seemed as if time froze for a long while--i could hear those mags flying every where..looked down and saw i lost the mags on one rotor..second rotor was still loaded with all mags..takes awhile for the alt to lose speed --doing all i can to stay away from that secound rotor..
--dang one close call--had a mag gaurd on it earlier[moped rear fender] but took it off to make ajustments--and of course forgot to remount it..
well what happened was -the finale pully[made from plywood] that mounts to the alt was a little off center and caused some vibration--it was okay at lower speeds but amplfied at the higher rpm--anyway the mags broke loose-stator was not damaged in any way..
i will rebuild it one more time and make a better set up-mount the bearings on each side with the stator and rotors in the middle...
just happened to look at the part number on my bearings[hmmm]
every thing i used those bearings on met with some sort of baddddd.....
still lookin for mags-lost four sets --found a few on the house roof -backyard-frontyard--be safe out their......later.
« Last Edit: June 03, 2006, 09:52:02 AM by (unknown) »
Re: big black and flyin mags
« Reply #1 on: June 03, 2006, 04:40:14 AM »
yikes! i got the same bearings, you made made me go check the casting numbers i'm ok.
« Last Edit: June 03, 2006, 04:40:14 AM by electrondady1 »
zubbly
« Reply #2 on: June 03, 2006, 05:06:23 AM »
hi Hiker!
if just one of those flying mags hit you in just the right place, you might have become, well........a unik   lol!
be carefull!
zubbly
« Last Edit: June 03, 2006, 05:06:23 AM by zubbly »
Titantornado
« Reply #3 on: June 03, 2006, 08:18:28 AM »
Any idea at what RPM things went wrong?
« Last Edit: June 03, 2006, 08:18:28 AM by Titantornado »
« Reply #4 on: June 03, 2006, 11:05:15 AM »
Thats pretty neat, except for the flying magnets of course.  I built one with an off the shelf DC motor, but there was a little vibration in the mount that would cause the chain to jump off every once in a while.  I've yet to get around to fixing that.  It's been sitting in a basement unused for a year or more now.  Rich
« Last Edit: June 03, 2006, 11:05:15 AM by richhagen »
« Reply #5 on: June 03, 2006, 04:07:37 PM »
must admit thats about the most dumb'est thing ive done yet..
could have very well been the last......
« Last Edit: June 03, 2006, 04:07:37 PM by hiker »
reinoud
« Reply #6 on: June 03, 2006, 04:13:47 PM »
Am i right to note that you are indeed using poly-urithane (PU)? (spelling?) for the stator?
Nice bearing blocks btw, i've got a couple of them here too :-D nice idea to put the two bearings like this on oposit sides; maybe it could fix a little bearing slack i found in a similar one.
The thing i'm curious about is the mounting of the rotor blades to the axle, have you machined a hub for it? or what have you used for it? I'd love to see an image of it for i'm struggling to find a good solution for it myself. My temporary solution is to use another bearing there, but that might not be the best way to do it ;)
cheers,
Reinoud
« Last Edit: June 03, 2006, 04:13:47 PM by reinoud »
« Reply #7 on: June 03, 2006, 04:49:28 PM »
it was geared up  to about 10 to 1..
one turn of the crank = 10 on alt..
i had it going at some outragest rpm....
it was a great set up[was made as a windgen]--next time i will spread the bearings across from each other..
shorted out to a auto amp meter it would put out 33 amps at 1.7 volts.thats with me pedaling like a mad dog in heat...........
with a 50 watt load you didn"t even no it was there--100 watts you could feel it some what-like riding a bike on a flat road--at 300 watts  you could feel the load--but still manage to pedal for awhile[all depends on what shape your in]..
  i have another bike with a motor conversion mounted on it...works okay for 110 volt use..maxs out about 300watts --but its a lot harder to get that--have to fight all the resistance in the wire..will post some picts of that if anyone is interested..
« Last Edit: June 03, 2006, 04:49:28 PM by hiker »
« Reply #8 on: June 03, 2006, 05:10:30 PM »
thats a plywood stator -with cutouts for the coils--then the coils are pressed in..
had some old boat resin laying around so i used that to secure the coils-
every thing was compressed between two plywood disks-untill the resin setup..
my hub is  made from layers of plywood -with angled cutouts for the blades..
it all slides over the 3/4" shaft and bolted down..
« Last Edit: June 03, 2006, 05:10:30 PM by hiker »
reinoud
« Reply #9 on: June 03, 2006, 06:55:27 PM »
thanks a lot for your info. I've got another question though :) how do you connect your rotor discs (with the magnets) to the axle? Do you use a layered aproach there too and glue or bolt them too?
Nice idea about the stator; i was playing with the idea too though i'll have to abort my plans for that in my current project since the coils are too close to eachother. A variation with a plywood disc and a plywood rind would work though! Attaching the coils with some fiberglass matts and resin to the plywood... now that would save heaps of resin/epoxy! thanks for the idea :)
cheers,
Reinoud
« Last Edit: June 03, 2006, 06:55:27 PM by reinoud »
« Reply #10 on: June 03, 2006, 07:44:09 PM »
those are 12" saw blades--i put a 7.5 saw blade on front and back side of each blade to help make it more ridged--mags are glued on plus nylon strapping tape wrapped around the outer side..rotors are bolted on to the 3/4" shaft -nuts are super glued also..
real hassle to take apart--i belive the super glue works better than locktite..
i would like to screw those mags on--wonder if they make a drill bit  for ceramic materail?
or i could make some cutouts[for the mags] in a piece of plywood and then screw that down to the rotors...later............
« Last Edit: June 03, 2006, 07:44:09 PM by hiker »
« Reply #11 on: June 03, 2006, 07:58:40 PM »
32 mags per rotor[lowes ceramics]
made into 8 block mags double stacked per rotor.
may have over loaded the blade[one blade is not as thick as the other]
think i will use a single layer of mags on that blade from now on..
just some more info.............
« Last Edit: June 03, 2006, 07:58:40 PM by hiker »
