Author Topic: torkmaster update  (Read 1399 times)
Stonebrain
torkmaster update
« on: June 14, 2006, 09:25:52 PM »
Got a camera with optics now
So have to show that I'm really working!
I widened up the mould on the most outer part.I delimited the bladeshape with
nails and tape.I opened up the shape at the base of the blade.Looks better.
After waxing,drying and polyvinylalcohol and drying put on the gelcoat.
This is the gelcoat for moulds.Came out very bad.It got soft when I went
glassing on it and messed up.Maybe it didn't cure well du to low temp.(about 10°C)
Next time I start glassing straight on the mould.So I can polish the inside
before putting the finishing gelcoat.(there are quit some imperfections
on the wooden mold)
these are the glassing materials
this is the famous roller.
it was finally not of much use.It tended to mess up the glas fiber and the washers
got stick together after the firdt use Even after soaking it in aceton.
I did all the glassing with a brush,small amounts of resin each time.
I did one layer of "cloth"heavier cloth at the base and light cloth at the outside
 and one and a half layers of mat,two layers at the base  and one on the outer part.
I evened some with the rasp.
It came easily off the mould.Then I cut the edges with a diskmill (carefull with that!)
Then two layers of resin,then sanding and finishing gelcoat
Here fixing together the two blades.Trick with wire through the center to space
them at 180 degrees
So far this time.Soon it will be flying
cheers,
stonebrain
« Last Edit: June 14, 2006, 09:25:52 PM by (unknown) »
Re: torkmaster update
« Reply #1 on: June 14, 2006, 04:17:02 PM »
Hello Stonebrain
 That is one cool lookin machine and can see youve been busy.Any plans for the driveshaft yet?
« Last Edit: June 14, 2006, 04:17:02 PM by vawtman »
WXYZCIENCE
« Reply #2 on: June 14, 2006, 04:46:18 PM »
Stonebrain, you will be teaching the future generation about fiberglas. Looks like a great big sea shell by the sea shore. Windmills are an art-form! Can't wait till you post it flying. Joe.
« Last Edit: June 14, 2006, 04:46:18 PM by WXYZCIENCE »
« Reply #3 on: June 14, 2006, 09:49:57 PM »
that's a great looking unit !
« Last Edit: June 14, 2006, 09:49:57 PM by electrondady1 »
Stonebrain
« Reply #4 on: June 15, 2006, 04:52:21 AM »
The driveshaft,I have it,but must be repaired.
Will be in my next diary
« Last Edit: June 15, 2006, 04:52:21 AM by Stonebrain »
