Author Topic: Inverter Chicago Electric Item #94009 1,000 Watt  (Read 3715 times)
coldspot
« on: June 22, 2006, 12:23:24 AM »
A couple weekd back I was talking to a friend about RE
and his friend had an inverter he'd sell me for thirty-five dollars
and at 750 Watts I'd said I'd take when i had some bucks.
So today when I stopped by there to pick up 750 unit
he couldn't find it and kind of talked like they thought I
already had it. No I told him, bummer cause I was looking forward to
trying it out this week end.
 So he tells me he should just sell me his own unit anyway.
And I asked what he wanted for it and he said  he gave about fifty for it.
Sold I said and also asked if it was tested?
He said he hadn't yet but I would let him know he was sure, if it didn't work.
So for fifty bucks I scored a
Chicago Electric Item 94009
  1. Watt 2000 peak
  2. Vdc
Inverter
It works
took me about 5 min to test and was on my way
Smiles
LOL
« Last Edit: June 22, 2006, 12:23:24 AM by (unknown) »
$0.02
coldspot
Re: Inverter Chicago Electric Item #94009 1,000 Wa
« Reply #1 on: June 22, 2006, 12:28:25 AM »
After DL'ing the owners manual
This unit has on the back-
Pos
Neg
Ground
The manual talked about grounding to
chassis, in boats and cars
But nothing about the home?
I quess the ground goes to the NEC green wire
Anybody out there with experience on a simular
set-up????????
« Last Edit: June 22, 2006, 12:28:25 AM by coldspot »
$0.02
DanG
bzzzt >pop<
« Reply #2 on: June 22, 2006, 07:08:47 AM »
Most portable inverters intentionally omit residential code neutral to ground bonding.
If you use your multimeter and find 60 volts between the 120VAC neutral line (wide blade on AC plug socket or white wire) and chassis ground know you will destroy the inverter by inserting it into a NEC standard system.
Standard house current has AC source all from the narrow blade on plug socket or black wire at full 120V potential, a temporary inverter will have 60V on both sides of plug-socket wiring.
I've read a couple explanations for this, the best being lowered electrocution risk if/when wiring is damaged or ground fault in an RV or boating situation.
« Last Edit: June 22, 2006, 07:08:47 AM by DanG »
coldspot
« Reply #3 on: June 25, 2006, 07:14:53 PM »
"bzzzt >pop<"
I'm not in the habit of letting out the magic smoke
This Inverter will be used in an OFF GRID cabin
There will be only what I put in the wires and nothing else
« Last Edit: June 25, 2006, 07:14:53 PM by coldspot »
$0.02
