Author Topic: blade almost done  (Read 1921 times)
blade almost done
« on: July 04, 2006, 04:16:44 AM »
this is the blade now , its curing in the vacuum bag.
i hope this comes out ok.
i've finised the outside shell on both sides it looks really nice.
i had a tough time figuring how to get the two halves to meet correctly at the trailing edge .but vacuum baging seems to do the trick..
i just checked it , it looks done !!
i'm going to leave it on for a little bit more
« Last Edit: July 04, 2006, 04:16:44 AM by (unknown) »
Re: blade almost done
« Reply #1 on: July 03, 2006, 10:55:26 PM »
why does the blade look like the foam blanks i was doing before ,you might ask?
thats because i didnt know how the canned foam would turn out , so i made another blade and first epoxied it to one half, then i epoxied the leading edge , and just now i epoxied the windward half to the shell , and the trailing edge.
« Last Edit: July 03, 2006, 10:55:26 PM by willib »
« Reply #2 on: July 03, 2006, 11:08:42 PM »
it was still tacky so i used a few clamps to seal the trailing edge a little better
« Last Edit: July 03, 2006, 11:08:42 PM by willib »
« Reply #3 on: July 03, 2006, 11:34:52 PM »
really shiney huh?
that is the lift part of the blade you are looking at .
the shell is epoxy and glass , the inside is shaped foam
now i have to trim the trailing edge , epoxy the root base on , (that i hook the blade to the hub with ) and test it.
« Last Edit: July 03, 2006, 11:34:52 PM by willib »
jmk
« Reply #4 on: July 04, 2006, 07:45:11 AM »
 Nice work! That vacum bag must realy help to lay the fiberglass down. What tsr do you expect to get out of them? Do you have an alternator-machine to put it on?
« Last Edit: July 04, 2006, 07:45:11 AM by jmk »
« Reply #5 on: July 04, 2006, 10:35:47 AM »
They are TSR 6
although i did vaccum bag the first half of the mold that i made ,and this last step , those were  the only times i used the vacuum bagging.
because i found out that to make the mold i didnt need vacuum bagging , because i layed up the glass in strips , with the same orientation as the foam, and was able to get a really nice finish on the mold without vacuum bagging. ie no seperations and no bubbles
i really like the sound it makes when i tap on it with my  finger , just like a surf-board.
on the next one i  have to try the canned foam , so the steps will be
make another shell , both halves,
make a mold to hold the shells in place as i use the canned foam for the core.
easier said than done , but that is the next step.
yeah i have a small alt allready made , but i'm going to change that around a little , down the road i'd like to redo the stator , and rotor , to use more magnets , because i have the room in there for three more coils , for a total of twelve . but thats not on my priority list.
« Last Edit: July 04, 2006, 10:35:47 AM by willib »
