Author Topic: Union Rectifier  (Read 5279 times)
coldspot
Union Rectifier
« on: August 29, 2006, 10:26:54 AM »
This came with the Jacobs 1800 Watt I got last weekend
« Last Edit: August 29, 2006, 10:26:54 AM by (unknown) »
$0.02
elvin1949
Re: Union Rectifier
« Reply #1 on: August 29, 2006, 06:36:10 AM »
Coldspot
 It just keeps getting better and better.
I don't think anyone else was keeping up with the other thread.
GUY'S
Check his file's.He got the whole system,up to and including the battery bank.[NiFe  so it should still be useable.
Getting greener by the min.
elvin
« Last Edit: August 29, 2006, 06:36:10 AM by elvin1949 »
Re: Union Rectifier
« Reply #2 on: August 29, 2006, 08:49:53 AM »
yeah i didnt know that he got the jacobs!
if ya want to search the patent you could probably find a complete schematic.
Aug 23 1927, #1640335
« Last Edit: August 29, 2006, 08:49:53 AM by willib »
coldspot
Re: Union Rectifier
« Reply #3 on: August 29, 2006, 10:17:32 PM »
Guys
"Union Rectifier
A.C. Volts   110,   Cycles    50/60
Max D.C. Volts 13.5,  Max D.C. Amps  .90
Style  RST-11     PC.  219694
Spec.  3329
  Serial No.
    H60448  "
Looking a bit off by todays standards
I think
O-well
« Last Edit: August 29, 2006, 10:17:32 PM by coldspot »
$0.02
Re: Union Rectifier
« Reply #4 on: August 30, 2006, 02:18:53 AM »
Mr Grondahl ,the holder of the patent calls it a " unidirectional current carrying device "
selenium diodes were common before semiconductors
interesting
« Last Edit: August 30, 2006, 02:18:53 AM by willib »
Re: Union Rectifier
« Reply #5 on: August 30, 2006, 02:21:53 AM »
 but expensive i'm sure
« Last Edit: August 30, 2006, 02:21:53 AM by willib »
drdongle
Re: Union Rectifier
« Reply #6 on: August 30, 2006, 05:25:16 AM »
These days we call it a "battery charger"
« Last Edit: August 30, 2006, 05:25:16 AM by drdongle »
jimjjnn
Re: Union Rectifier
« Reply #7 on: August 30, 2006, 06:57:32 AM »
Selenium rectifiers can be replaced with diodes or brdge rectifiers. Replace with higher voltage and higher current ones.
« Last Edit: August 30, 2006, 06:57:32 AM by jimjjnn »
coldspot
Re: Union Rectifier
« Reply #8 on: August 30, 2006, 07:04:52 AM »
jim-
But this stuff is just
"Collecter" type
And I have way better
and modern systems.
I'm just sharing what
I find with the board.
LOL
PS: I'm not a collector type
just a good pack-rat type
LOL
« Last Edit: August 30, 2006, 07:04:52 AM by coldspot »
$0.02
coldspot
Re: Union Rectifier
« Reply #9 on: August 30, 2006, 07:15:03 AM »
willib-
WOW
Nice pic
Please-
If you could,
"Best" Inverter
"B32-3000"
I have factory sheets and sales booklet
from them but the NET seems to be lacking of any
info, in my limited searches so far.
This sucker is 75 Lbs 3K Watts with surge to 12K Watts!!!!!!!!!!
Even has a plug in for remote, lol
« Last Edit: August 30, 2006, 07:15:03 AM by coldspot »
$0.02
jimjjnn
Re: Union Rectifier
« Reply #10 on: August 30, 2006, 10:48:01 AM »
12K !! use it !!!!!
« Last Edit: August 30, 2006, 10:48:01 AM by jimjjnn »
coldspot
Re: Union Rectifier
« Reply #11 on: August 30, 2006, 12:21:57 PM »
"use it !!!!!"
Without a dought!
As soon as I get a system that I can get to
the required in-put V.D.C.
"28 to 38"
I'm still on 12 V.DC here
Many, Many mini mills and NO place
to play with them. :(
Might get it tested later today-
« Last Edit: August 30, 2006, 12:21:57 PM by coldspot »
$0.02
drdongle
Re: Union Rectifier
« Reply #12 on: August 30, 2006, 03:03:16 PM »
When replacing selenium rectifiers with silicon you should first check the current and possibly increase the series resistance. Seleniums have a higher series resistance than silicons. In the days of transition from vacuum tubes to solid state it was common to convert older power supplies to silicon.
« Last Edit: August 30, 2006, 03:03:16 PM by drdongle »
Re: Union Rectifier
« Reply #13 on: August 30, 2006, 09:47:08 PM »
Selenium diodes ARE semiconductors.  B-)
(But they were in use before a theoretical explanation of how semiconductor diodes work was developed - an explanation that led immediately to the (re)invention of the point-contact junction transistor.)
« Last Edit: August 30, 2006, 09:47:08 PM by Ungrounded Lightning Rod »
BT Humble
Re: Union Rectifier
« Reply #14 on: August 31, 2006, 04:30:39 AM »
Re-invented you say?  So who was the poor devil who missed out on patenting it prior to Bardeen, Brattain & Shockley?  ;-)
BTH
« Last Edit: August 31, 2006, 04:30:39 AM by BT Humble »
Re: Union Rectifier
« Reply #15 on: August 31, 2006, 09:55:36 PM »
It got patented but had long expired by the time that crew designed (not discovered) their transistor.
If you've ever tried positioning a cats-whisker on a piece of galina to make a diode for a crystal set, imagine positioning TWO of them correctly so the interaction makes a working point-contact transistor - and doing this half a dozen times -= with them ALL working - to get enough working stages of amplification to have an effective radio.
I think what happened is that the gain was too low and the construction too chancy, and people believed that it was bogus.
Remember that - except for perpetual motion machines (where they demand a working model as a way to keep the crackpots out of their hair) - the patent office is only concerned with novelty, not with whether the thing actually works.  (That's between the inventor and his licencees.)
« Last Edit: August 31, 2006, 09:55:36 PM by Ungrounded Lightning Rod »
