Author Topic: Setting up and Tuning the Lenz Education Turbine  (Read 1002 times)
battle
« on: August 31, 2006, 04:23:49 PM »
Setting up and Lenz Education Turbine the first lab session
Component Testing stator winds and magnet layouts
The Wind Tunnel - for low velocity and low cost
Note fans draw air through the tunnel to avoid turbulence.  Constructed of art foam board with an inverse contraction cone at exit.  No contraction cone at air supply means students need to stay away from the opening to avoid inbound turbulence and other unwanted variances.  You can also see a three prop turbine built acetate sheets around aluminum air foils from the craft store.  Haag-Streit anemometer in left foreground, and strobotach reflector in right foreground.
huge pics removed
Kurt
« Last Edit: August 31, 2006, 04:23:49 PM by (unknown) »
Countryboy
800 to 1800 KB pics
« Reply #1 on: August 31, 2006, 11:02:39 AM »
Hi battle,
  Learn to resize pictures properly.  There is ZERO excuse for you not resizing your pictures to under 100 KB each.
« Last Edit: August 31, 2006, 11:02:39 AM by Countryboy »
pyrocasto
Re: 800 to 1800 KB pics
« Reply #2 on: August 31, 2006, 12:00:46 PM »
You stated the reason, people dont know how. Instead of getting my panties in a bunch, I'll just do everyone a favor. ;)
« Last Edit: August 31, 2006, 12:00:46 PM by pyrocasto »
« Reply #3 on: August 31, 2006, 06:42:15 PM »
a couple of young guys doing some science, looks great!
« Last Edit: August 31, 2006, 06:42:15 PM by electrondady1 »
