Days 8 and 9:
I'm pretty excited how my stator turned out! It has a few surface blems but it looks like it's going to work out.
Here's some pics -
I wired the coils then tacked them together like Dan shows in his instructions. I took the coils out and soaked them in a 50/50 mix of resin and ATH; then I put them in a bag and pulled a vacuum.
My theory is that when the vacuum is slowly released that the vacuum in the coils will suck in the resin... well, I read that that's how they oil emeralds (which infuses the cracks and flaws with oil so that it looks brighter.) My hope is that by getting the ATH in there that the coils will lose heat better.
I put another coat of wax on the mold and started to pour the stator, though "pour" isn't exactly how it went...
I poured in some resin, put in the fiber glass fabric then after saturating and smoothing out the fabric, I put the coils in. I mixed up a pint of resin, a cup of 1/2" chopped strand and a cup of AHT. (mix ratio 50/25/25) It was still a little soupy and would have taken some more chopped strand but it the chopped strand was longer and stringier than expected and I was concerned about getting all the crevices filled if I added more. At any rate, it certainly wouldn't "pour." I ended up using a paint stirring stick to scoop the mix into the mold and the end of the stick to push it down into the smaller areas... the picture is a little bit past half way through the pour... what a mess! Well next time I'll use 1/4" chopped strand, I think that will be easier going.
After I got the body of the mold filled, I poured on some resin (without additives) and put on the top piece of fabric. When it was clamped up I got a enough squeeze out that I felt like I had enough resin in there. I checked on it after an hour and the mold was nice and warm to the touch. After about four hours it was mostly cooled down so I thought that I'd pop it open.
Well that top came off very easily. The stator didn't pop out, though, and it didn't come out with a gentle thumping. I whacked and whacked; no good. I took a pry par to the mold and after I had the ring loosened, the stator finally fell out.
Here's a picture of the stator -
This is the "bottom" of the mold; you can see it's a little scalely where the resin mingled in with the wax. Eventually I'll scrape and sand and it and paint it. For now, though, I'll let it lay flat overnight, then I'll drill the holes for the mount tomorrow. I can't wait to get it in between the rotors and check the volts...
- Ed.
