Author Topic: Honda Ct90 engine rebuild  (Read 5171 times)
BT Humble
« on: November 21, 2006, 02:07:10 AM »
Here's the bike as it looked back in July (just unloaded off the
truck):
http://www.otherpower.com/images/scimages/236/ct90_2.jpg
I decided that it would make a good paddock bike for my 10-year-old
niece (she's a bit too tall for the "family minibike").  About $250
later it has:
  • A functioning front brake;
  • A functioning ignition system[1];
  • A cleaned-out carburettor;
  • A new piston, rings, and 0.5mm overbored cylinder;
  • A sidestand.
I had a bit of e-bay luck on some CT90 parts in Wagga Wagga which my uncle
collected for me, $18 bought the correct seat[2], exhaust heat shield,
front mudguard, spare forks[3], spare fuel tank, and centrestand.  I've
got a CT90 wreck at my farmlet that still has a brake pedal and rod
attached.
It was interesting to learn that the fork oil seals can be bought from
a bearing shop for $1.50 each, if you know the numbers for them.  A motorcycle shop generally charges about $25 a pair. :-/
Amazingly it started on the first kick after reassembly.  It runs in a
very smoke-free manner until the exhaust pipe gets hot, which is full
of oily muck due to being run with a broken compression ring and
worn-out oil scraper ring[4] for Quite Some Time.  The exhaust port was
about 25% smaller than it should have been, due to a thick layer of
oily, sooty goo.
And after the disastrous new-camchain-fitting incident on my CBR1000F[5], I checked the tightness of the camshaft bolts VERY carefully!
BTH
[1] I recycled the old ignition coil & condenser from my truck, and a
suitable 6V battery for $14 from Jaycar.
[2] It has the narrow seat of the first k0 model, where it should have
the current CT110 wide one.
[3] In case the fork sliders on it are too rusty to fit new seals to.
[4] The "wear limit" for the piston ring end gaps is 0.5mm, the
unbroken ones were about 5mm.
[5] A bolt worked loose from the sprocket on the exhaust cam, fell into the cam tunnel, snapped the camchain, and bent 4 of the 16 valves in the motor.  Fortunately I was stationary at the time...
« Last Edit: November 21, 2006, 02:07:10 AM by (unknown) »
whatsnext
Re: Honda Ct90 engine rebuild
« Reply #1 on: November 21, 2006, 09:40:13 AM »
Those things are fantastic. I just sold a Jialing Passport and before that my CT90. It's unbelievable how effective those things are as transport devices if you are will to brave the elements and stay below 50mph. I love my big bikes but the little tiddlers have been a never ending passion for the last decade or so. I'll post pictures of my current CB125 project once it get's a little closer to being road worthy.
John.....
« Last Edit: November 21, 2006, 09:40:13 AM by whatsnext »
