Author Topic: Wind  (Read 1169 times)
bj
Wind
« on: November 22, 2006, 12:04:24 AM »
    Almost no wind today, so put up the next try.  Another GM alt,
with the big Neo in it, but different windings, and a larger size.
    This one put out 39 volts @ 300 rpm, open circuit.
    A half inch differnce in rotor diam seems to make about 10
volt difference.  (same number of winds, same size wire, same Neo)  Just
checked, 5/8 ths inch difference.
    Hopefully have the cable wrapping problem solved.  (thanks to Ghurd)
    Anyway, will post when the wind comes up.
    I know most of you would prefer to build from the ground up, and
I must say your results are great.  I am sticking to the GM's mostly
as a cost saving measure.  I have literally hundreds of these things,
and the time.
    bj
« Last Edit: November 22, 2006, 12:04:24 AM by (unknown) »
bj
Lamont AB Can.
drdongle
Re: Wind
« Reply #1 on: November 21, 2006, 06:11:21 PM »
how about some pictures?
« Last Edit: November 21, 2006, 06:11:21 PM by drdongle »
bj
Re: Wind
« Reply #2 on: November 22, 2006, 04:50:10 AM »
   Dr.D--will post pics when I figre out how to remain in the
limits.  Damn camera takes wonderful shots, but huge files.
   Sorry, and thanks.
   bj
« Last Edit: November 22, 2006, 04:50:10 AM by bj »
bj
Lamont AB Can.
DaveW
Re: Wind
« Reply #3 on: November 22, 2006, 08:22:13 AM »
  Use something like irfanview (download for free from net) and load your image. Under image click on resize/resample and select the 640 size. Save the reduced image and check it for size before posting. Works great, costs a little download time, and keeps the cookie monster from deleting your pictures.  A small picture is still worth 500 words.
« Last Edit: November 22, 2006, 08:22:13 AM by DaveW »
Re: Wind
« Reply #4 on: November 23, 2006, 06:26:19 AM »
bj,
it might be a dead end but have you concidered using the output of your modified alternator to power up a second one .
i would think the second one would need a rewound stator as well.
« Last Edit: November 23, 2006, 06:26:19 AM by electrondady1 »
bj
Re: Wind
« Reply #5 on: November 25, 2006, 05:17:29 PM »
    Electron--hope you don't mind the short version.  Yes, I have thought about that for a few days,  (Hint from someone on this board)  Will try,
and post the results.  Have a bunch of rewinds, from experiments, and
have several pairs of identical winds.  Also have two identical rotors.
    I am pretty sure that this won't work on A.C., but it stands a chance
on D.C..  Full wave bridge should help as well, which, at the moment
all of mine are.  (thinking of changing, with rect. @ Batts.)
    Hard to say, but might be an answer to getting the voltage up, going
to smaller wire, etc.
    Till then, thanks for the interest.
    bj
« Last Edit: November 25, 2006, 05:17:29 PM by bj »
bj
Lamont AB Can.
bj
Re: Wind
« Reply #6 on: December 13, 2006, 10:33:23 AM »
   As promised, I tried two P.M's in series.  Readings were at first
double, as expected.  After about two minutes, lost about 20% voltage.
This was an open circuit test.  No load.  Investigation showed up a
blown diode.  These are stock G.M. diodes, and I have had several
failures before.  So, am not sure if the failure is due to series
hookup, or just crap parts.  Seems that the flaw in using these
things as a base is the parts available. (quality)
   Having said that, upon rebuild, I will post again.
   Thanks for your interest.
   bj
« Last Edit: December 13, 2006, 10:33:23 AM by bj »
bj
Lamont AB Can.
