There are a handful of ideas that has drawn me to building one of these Wind Turbines:
- I like to tinker.
- Tinkering is more fun if you scrounge for parts and pieces.
- Renewable energy has always been interesting.
New steel is easier to work with and it sure makes things look nice, but I deceded I would just use whatever was lying around the shop to build the frame for this wind turbine.
The only real resembleance of this frame to the one in Hugh's plans would be the offset for the hub from center and the tail.
I had small chunk of channel iron so I opted for that, over the angle iron, for mounting the hub.
Here you can see the angle the tail was placed. The hub was taken off a 1988 Chevy Celebrity.
Here the side view shows the angle the tail leans away from the yaw bearing.
I scratched my head for a while on these angles. I thought..Wow if you think about it there are a number of compound angles here!
My problem was that I was thinking about this too much. In the end the tabs that hold the tail on where both cut with no angles at all, in fact they are identical in every way. The only "special" cut was the cope to make them fit the pipe.
Here is a rear view shot. If I remember right the tail is about 6' long.
I really like the pipe tails and tail hinges that people are building here, but I thought I better build it as close as possible to Hugh's design on my first one. No matter the urge and it was tuff... I didnt really change anything from Hugh's design, at least nothing that would make it perform differently.
Haveing said that... Here is a shot of the tail stop that was not in the plans..
Another of the tail in the furled position.
During the alternator assembly I built the stator mounts which are not shown in these pictures - but will be in one of my next diary entries.
All that is really left on the frame is paint. I haven't decieded on a color yet, but it's probably going to be a sky color of some sort.
Wil
