Author Topic: DIY Anemometer  (Read 11658 times)
DIY Anemometer
« on: May 01, 2007, 06:18:32 AM »
I started with a pc powersupply fan (pcf or ppf ), one with ball bearings , cut the stator/ armature off and it spins as free as the wind.
did a little rewireing , very little .
and connected it to my meter reading frequency , and got the graphs shown below.
each graph is later in time than the one before it.
cool huh?
« Last Edit: May 01, 2007, 06:18:32 AM by (unknown) »
Re: DIY Anoemeter
« Reply #1 on: May 01, 2007, 12:22:26 AM »
anemometer
crap could someone fix the spelling please
« Last Edit: May 01, 2007, 12:22:26 AM by willib »
commanda
Re: DIY Anoemeter
« Reply #2 on: May 01, 2007, 12:27:12 AM »
I take it you have one of those multimeters with the serial RS232 pc connection?
I've got one of them. Wonder if anyone has any Linux software for it so I can actually use it some day?
« Last Edit: May 01, 2007, 12:27:12 AM by commanda »
Re: DIY Anoemeter
« Reply #3 on: May 01, 2007, 12:29:26 AM »
yeah its just a rat shack ,but i like it
« Last Edit: May 01, 2007, 12:29:26 AM by willib »
Re: DIY Anoemeter
« Reply #4 on: May 01, 2007, 12:36:37 AM »
You shouldn't let it loose with your amoebas, it probably mated with them.
« Last Edit: May 01, 2007, 12:36:37 AM by Flux »
Re: DIY Anoemeter
« Reply #5 on: May 01, 2007, 01:08:39 AM »
cheerio ole chap
pass me a tea if ya would
thanks so much .. :)
« Last Edit: May 01, 2007, 01:08:39 AM by willib »
Re: DIY Anoemeter
« Reply #6 on: May 01, 2007, 03:39:02 AM »
Oh You take the dequency of the fan hall with your neter compare the out put with a working annomomer  and then throw the annomomer in the  ebay.
« Last Edit: May 01, 2007, 03:39:02 AM by tecker »
Done
« Reply #7 on: May 01, 2007, 04:22:32 AM »
(blank)
« Last Edit: May 01, 2007, 04:22:32 AM by TomW »
Re: DIY Anoemeter
« Reply #8 on: May 01, 2007, 04:26:21 AM »
Commanda;
Google up "zmeter" its pretty fair and I think its on Sourceforge.
Ibedonc hacked up a version for me.
« Last Edit: May 01, 2007, 04:26:21 AM by TomW »
Re: DIY Anoemeter
« Reply #9 on: May 01, 2007, 04:27:59 AM »
« Last Edit: May 01, 2007, 04:27:59 AM by TomW »
commanda
Re: DIY Anoemeter
« Reply #10 on: May 01, 2007, 08:16:09 AM »
Tah, I'll check it out.
« Last Edit: May 01, 2007, 08:16:09 AM by commanda »
Re: DIY Anoemeter
« Reply #11 on: May 01, 2007, 08:52:09 AM »
the fan circuitry is made for 12V , but if i put in 5v or so power i get a 5v squarewave out. nice for digital work..
and the fan consumes less than 5mA at 4.5 volts
removing the armature is key to  success
i used a dremmel to cut the armature off , being careful not to cut too deep into the bearing mount.
« Last Edit: May 01, 2007, 08:52:09 AM by willib »
Re: DIY Anoemeter
« Reply #12 on: May 01, 2007, 09:03:37 AM »
yes i use the hall switch in the fan and the magnet , so the output is two changes in digital per revolution.
say it starts out low...
it will go high , then low ... then high and back low in one revolution
« Last Edit: May 01, 2007, 09:03:37 AM by willib »
Re: DIY Anemometer
« Reply #13 on: May 01, 2007, 09:17:38 AM »
at 80 hz i calculate it was spinning at 2400 rpm , not bad ..
« Last Edit: May 01, 2007, 09:17:38 AM by willib »
Re: DIY Anemometer
« Reply #14 on: May 01, 2007, 08:48:23 PM »
ok i got the program on a laptop now,
and i am powering it with a 12V battery , should be good to take out for a ride , and calibrate it with the cars spedometer
its an old micron go book with an external battery as the "only" battery..
funny thing i had to fool the external battery into thinking i was using the cells included ..
when in fact i cut the negative and put in a jack for 12V
it had something to do with the equilization of the six batteries that were in there..
anyway i soldered three 10K resistors to the tabs between cells and it works now..
this Micron is a power hungry beast
« Last Edit: May 01, 2007, 08:48:23 PM by willib »
wind gauge on a stick
« Reply #15 on: May 01, 2007, 10:08:15 PM »
a pipe really..
« Last Edit: May 01, 2007, 10:08:15 PM by willib »
Re: DIY Anemometer
« Reply #16 on: May 02, 2007, 06:00:38 AM »
It's a nice experiment, but whether it'd make a really suitable anemometer I have doubts of.
Like a windgenerator your anemometer would need a tail to keep it directed straight in the wind (or you'd have to manually do that).
The 'eggcup' anemometer doesn't have that requirement. In effect, it's a VAWT, whereas your anemometer is a HAWT... ;)
A while ago I found the cup for an anemometer. Mated it to a small DC motor, which gives plenty of voltage at low RPMs to use a small analog display. I still need to calibrate it though. What I like most about such a DC motor and analog display: it doesn't require external power. The wind provides the power for the readout. Can't get more 'RE' than that.
http://www.anotherpower.com/gallery/dinges/anemometer_resized
Yours is a nice experiment though.
« Last Edit: May 02, 2007, 06:00:38 AM by dinges »
Re: DIY Anemometer
« Reply #17 on: May 02, 2007, 10:26:50 PM »
Well peter i went out tonight and took some frequency measurements vs MPH of my car.
i did two runs for each mph , one one way , one the other way , this is what i came up with
« Last Edit: May 02, 2007, 10:26:50 PM by willib »
more pix
« Reply #18 on: May 03, 2007, 09:20:24 AM »
i had to beef up the gauge mount ,so i started with an arbor(sp) , like the one i sent ghurd
i filed the end of the stick so it fit inside the arbor , used a large screw to hold it on ,right down the center of the stick, then i put a small HD platten on top of the arbor.
drilled and tapped two 4-40 screw threads , used two "washers" and mounted the disk, this made a nice platform to mount the wind gauge
then i just used some steel wire , and put it through the "fan" mounts and twisted it closed
it would take more than a gale wind to knock the gauge off the stick
in this photo i got carried away with the hot glue ( to hold the wires in place),but they havnt come off yet so i suppose its ok
« Last Edit: May 03, 2007, 09:20:24 AM by willib »
Re: DIY Anoemeter
« Reply #19 on: May 09, 2007, 12:21:54 AM »
did ya get a fan open yet?
if anyone was gonna try what i did it would be you :)
to get the signal out of the fan , i connected a wire to the drain of one of the tiny fets on the circuit board.
if you put the hall switch near an alternating magnetic field ,you can scope out the signal pretty easily , then just apply 5V power and the signal is a 5V square wave out..
« Last Edit: May 09, 2007, 12:21:54 AM by willib »
