Author Topic: School project  (Read 923 times)
Devo
School project
« on: May 31, 2007, 12:06:33 AM »
I am helping my daughters boyfriend with a school project , a wind mill. I have 17 gauge wire at 40 wraps a coil that is the max I can fit in , I need 400 wraps so 17 gauge 2 times gives me 23 gauge & 80 wraps then 26 gauge would be 160 wraps , 29 gauge 320 then 30 gauge would be 33 % more or  up to 524 wraps.
Am I doing this right?
Devin
« Last Edit: May 31, 2007, 12:06:33 AM by (unknown) »
Re: School project
« Reply #1 on: May 30, 2007, 09:28:08 PM »
Devo , what size are your mags
what size rotors do ya have
« Last Edit: May 30, 2007, 09:28:08 PM by willib »
Re: School project
« Reply #2 on: May 31, 2007, 02:16:59 AM »
Sounds about right. You will probably find that you can get more turns with the finer wire as there is less wasted space so you may be able to use a grade thicker than the calculated.
I assume this is a tiny project and you are not expecting a lot out.
« Last Edit: May 31, 2007, 02:16:59 AM by Flux »
Devo
Re: School project
« Reply #3 on: May 31, 2007, 07:07:08 AM »
Yes it's a tiny mill,18" blades the rotor is a touch under 5 inches , 16 mags single rotor. magnets are 1/2" round 1/2" thick neo's.
I had thought about using the 17 gauge & running a 120 to 12 volt wall transformer backwards but I may just get some fine wire.
I am hoping to wire some D or C cells in series to get 12 volts & run a zener diode to activate a small dump load. the 12volt battery will run a small 12 volt car lighter inverter & then a 10 watt bulb(maybe).
Not sure if a mill that small with those tiny mags will make that much juice but I'll find out,if not I'll go with led's or something...
Devin
« Last Edit: May 31, 2007, 07:07:08 AM by Devo »
Re: School project
« Reply #4 on: May 31, 2007, 03:50:48 PM »
for an alt that small , have ya considered using a VCR head ?
for reference i made an alt out of 1/2"dia by 1/2 inch mags
three phase 18 coils ( six per phase), but my rotor ( single) was 7.5" dia
If i was to do it again i would have used thinner wire than AWG 20
because although i got 10 watts out of it it was at 500+ rpm IIRC
this was before the origional minigen
« Last Edit: May 31, 2007, 03:50:48 PM by willib »
