Author Topic: A Case For the Non-Cast Stator II  (Read 8663 times)
SamoaPower
Re: A Case For the Non-Cast Stator II
« Reply #33 on: June 29, 2007, 03:18:53 PM »
Dan,
Many thanks for the kind words and your perspective on the issues.
I certainly agree that other viewpoints should be aired for all to examine and ponder.
I have no doubt that from your perspective, having made dozens, the cast stator is a simple process that you could almost do in your sleep. I'm not so sure however, that many first-timers would find it so. Personally, I find making cut-outs in a piece of rigid FRP and bonding in coils a much simpler process.
I do disagree with some of your points but picking nits is not on the agenda today.
I guess my main thrust in all of this is that I don't feel comfortable going into the ball game with one strike against me, which is how I feel about the cast stator. Having the additional temperature safety margin, whatever it is, afforded by an open stator is a degree of insurance I welcome to help combat the vagaries of the wind and perhaps, the results of a less than perfectly matched design.
We all can probably agree that there is room for improvement on the current design of the axial flux alternator. I find striving to find some of these a challenging and fun endeavor.
Good luck to us all in finding better machines. I hope the search never stops.
« Last Edit: June 29, 2007, 03:18:53 PM by SamoaPower »
SamoaPower
« Reply #34 on: June 29, 2007, 03:21:12 PM »
« Last Edit: June 29, 2007, 03:21:12 PM by SamoaPower »
« Reply #35 on: June 29, 2007, 03:53:23 PM »
OK ,  you are the user that I was talking about that painted glue on the coils when winding them.
« Last Edit: June 29, 2007, 03:53:23 PM by wooferhound »
« Reply #36 on: June 30, 2007, 05:48:04 AM »
samoa power , we have all been waiting for eight months for you to finish the super stator .
have you had proplems with it's construction?
is it something we can help with?
« Last Edit: June 30, 2007, 05:48:04 AM by electrondady1 »
SamoaPower
« Reply #37 on: June 30, 2007, 07:50:24 AM »
electrondady1,
The test version of the stator awaits testing. Please see:
http://www.fieldlines.com/comments/2007/4/29/31050/2563/13#13
I had hoped to inspire others to pursue a non-cast approach and indeed, a few have.
Thanks for the offer.
« Last Edit: June 30, 2007, 07:50:24 AM by SamoaPower »
BigBreaker
« Reply #38 on: July 02, 2007, 12:29:09 PM »
The copper wire in the coil is a pretty good conductor of heat.  Cooling only a portion of the coil, but cooling it very well, will work.
Air cooling a portion of the coils does not work because air has such a low specific heat.  It absorbs very little heat energy before matching the coil.
« Last Edit: July 02, 2007, 12:29:09 PM by BigBreaker »
« Reply #39 on: July 02, 2007, 01:12:23 PM »
OK.
How do you cool it?
« Last Edit: July 02, 2007, 01:12:23 PM by Ungrounded Lightning Rod »
