Looks good to me!
The fan have multiple speeds, yes? That will make it confusing.
I had one where part of the coils were wired backwards to reduce the flux at the expense of more power used.
My best luck was usually separate phases, paralleled (Jerry Rigged). Some will cut in sooner / later than others. With the high resistances, it didn't seem to bother anything.
Looks like it may be possible to find where one coil wire goes to the next coil? Good luck with that, but it would certainly help get the efficiency higher by reconfiguring the coil arrangement.
Is the fan blade 40cm? Don't expect it to work very well, either for starting or high RPM. I save everything, but 16" blades go straight into the trash.
Smaller the gap, higher the output. If there is room, add HD neo pieces as 'pole shoes'. Helps FAR more than I'd have thought.
Thank you Zubbly.
"Hacksawed (tiring...) the rotor..."?
When I was you age we had to cut rotors down using only wet bird feathers.
