Author Topic: Thanks to all, I'm flying!  (Read 1544 times)
Jimmy D
« on: October 08, 2007, 08:55:23 PM »
This is Hughes 5 phase with a Colorado mount. Dans tower 101. If you get Hughes book and do your homework on this board, ask a few questions and it's not as bad technically as it would seem. No anemometer yet but a stiff breeze is yielding 25A at 12V. You guys and gals are the greatest, strong winds for all! Having a ball on Simcoe Island, Canada.
« Last Edit: October 08, 2007, 08:55:23 PM by (unknown) »
Volvo farmer
Re: Thanks to all, I'm flying!
« Reply #1 on: October 08, 2007, 06:16:59 PM »
Beautiful!
I think I'm familiar with Dan's tower 101. Did you use the same dimension pipe and height as is on the pencil drawing?
Nice work.
« Last Edit: October 08, 2007, 06:16:59 PM by Volvo farmer »
Less bark, more wag.
Jimmy D
« Reply #2 on: October 09, 2007, 06:51:01 AM »
Hello Volvo farmer,
The tower is pretty much identical to Dans pencil drawing, except the jin pole and both tower tubes are 2.75 OD 2.50 ID x 20'and the stub to engage the yaw bearing is 2.50 OD x 2'. Total height then is 42'. Also I put in a permanent hand winch at the jin pole anchor and can raise and lower the turbine myself although two people is safer. Turbine rotor is 8'carved to Hughes specs.
Jim
« Last Edit: October 09, 2007, 06:51:01 AM by Jimmy D »
Devo
« Reply #3 on: October 09, 2007, 01:58:08 PM »
Looks Fantastic,nice to see the ammeter going up isn't it-lol
Devin
« Last Edit: October 09, 2007, 01:58:08 PM by Devo »
Volvo farmer
« Reply #4 on: October 09, 2007, 06:00:48 PM »
Thanks for the response. I think that's the same pipe I have here. It's oilfield pipe and is about 2.75" OD, and comes in pieces about 30' long. I've been meaning to ask if it's stout enough for a 40' tower.
You have any pictures or description with materials on the hinge? I think I have everything I need to build my tower now. How did you join the two pieces for the 40' length?
Thanks,
VF
« Last Edit: October 09, 2007, 06:00:48 PM by Volvo farmer »
jmk
« Reply #5 on: October 10, 2007, 12:38:04 AM »
Congratulations, another beautiful sight!
« Last Edit: October 10, 2007, 12:38:04 AM by jmk »
