Author Topic: Update on swing power unit  (Read 4297 times)
« on: November 21, 2007, 01:44:29 AM »
  Here's the latest development in the bike
generator...a little more compact...or could be
Well for a little test I hooked this treadmill
motor up to charge a 5200Ma NiCad 4.8 volt
battery pack thaat I rigged up ....by rocking
one pedal back and forth...about a 1 foot stroke
, once a second I simulated a really casual
swinging session, the generator was spinning an
approximate speed of 300 rpm.
The voltage read about 3.98 initially, after about
30 minutes of casual "treadle pedaling" with one
hand....this was so easy it was almost ridiculous
, which is my aim ....casual swinging power.
  ...the battery pack was reading 5.24 volts.....
about 1.3 volt average per cell.
  Still there is much room for improvement, my
final version will be the back and forth motion
of the swing directly to the chain....the entire
mechanism under the floor of the swing except
for the generator and batterys.
     ( :>) Norm.
« Last Edit: November 21, 2007, 01:44:29 AM by (unknown) »
Re: Update on swing power unit
« Reply #1 on: November 20, 2007, 06:58:07 PM »
Making the kiddies work I see :-)  I observe that people usually swing from a seat held to a top pole by a chain.  I notice that they jump to a start and then put more energy into the swing a little at a time as it goes higher.  Two questions come to mind.
First, how much power can you take out of the system - dampening - before it becomes difficult to swing, and second, some of the energy will be lost if the alternator is too stiff from the gearing at the pedal because the chain will bend some below where it is attached to the alternator.  I'm sure the forces could be calculated, and I don't think that is a big issue in your case because you can rock it gently without applying much force with your hand.
You could power an automatic light near the swingset for those night time swinging sessions.  Rich
« Last Edit: November 20, 2007, 06:58:07 PM by richhagen »
2dumb2kwit
« Reply #2 on: November 20, 2007, 08:17:29 PM »
 Looks great norm, I like the way you think!
I would like to add something to rich's idea, if I may. If you power a light with your swing-gen, I think you should put the light above your head,......that way when you start to swing, the lightbulb will pop on above your head and everyone will think you just had another idea!LOL
« Last Edit: November 20, 2007, 08:17:29 PM by 2dumb2kwit »
« Reply #3 on: November 20, 2007, 08:23:08 PM »
This isn't a chain swing this is a glider swing
, the roof and the floor form the top and bottom
legs of the parallelogram, the end legs are the
sides that are part of the seats...as you swing
forward, you push forward with the lower part of
your legs and feet on the floor...thats the power stroke.
  I figure about 20 watts steady is enough for
me...
   Then again my next project could hook an air
compressor to the swing storing the air to run
an air motor cylinder type connected to a generator
 large enough to run a small light.
    All fun learning nothing to get off the grid
about.
          (  :>) Norm.
« Last Edit: November 20, 2007, 08:23:08 PM by Norm »
« Reply #4 on: November 20, 2007, 08:25:18 PM »
Ah Yes...it would be a dim bulb....!
            ( :>) Norm.
« Last Edit: November 20, 2007, 08:25:18 PM by Norm »
Stonebrain
« Reply #5 on: November 21, 2007, 07:20:52 AM »
Hi Norm,
did you think off an lineair alternator.I saw pocket lights that keep the accu loaded just by shaking it a bit.Seems quite efficient.
For the swing movement it would mean less transmission losses.
Just a thought...
Really cool project.
cheers,
stonebrain
« Last Edit: November 21, 2007, 07:20:52 AM by Stonebrain »
feral air
« Reply #6 on: November 21, 2007, 11:01:59 AM »
It sounds to me like you can reduce the size of the pulley on the motor a bit if it's that easy. Or...
I'd look into internally geared hubs (xmas present for self?). That would let you up-shift once you hit your stride to get the motor spinning faster. Even cooler would be an automatic hub/derailleur, if you can find one (that's not outrageously expensive and) that'll work in your setup, since it could be tough trying to reach a shifter while in the swing.
20w would only be my goal for kids. 50w or more for adults. I know you don't want it to be too much like work but I think you've got enough weight on your side to make 50w achievable...maybe even 100w or more.
Anyway, it looks awesome - like an over-sized dynamo mounted kind of funny. take it easy
« Last Edit: November 21, 2007, 11:01:59 AM by feral air »
« Reply #7 on: November 21, 2007, 01:21:00 PM »
Hey Norm;
  Very nice !! I took a look at those Batteries, I'm thinking you're getting low and need more:-)
I've stole your idea of adding 4 more to make a dual 12Vdc unit, but I've found so many thing run on the 10V level that I just double up the current by splitting them down the long ways. Makes two sets of 8 right at a solid 10Vdc and double the current. I use a small 25Watt solder iron and solder on to the tabs that are right there for the using.
 Makes pretty easy to charge too.
You need more of those packs, let me know and I'll drop ship some.
Have Great FUN
« Last Edit: November 21, 2007, 01:21:00 PM by Bruce S »
« Reply #8 on: November 21, 2007, 04:15:55 PM »
Yes indeed I do and thanks so much ! You have
helped open up a whole new adventure series for
me. I lean toward 6 and 12 volt systems.
 I no longer worry about soldering I'm developing
 a rack system for each of my appliances
something like cartridge fuse holders (hmmm...
loongg fuses) I'll post a couple of pics here
of how I'm doing it.
 I think you'll like it !
               ( :>) Norm.
« Last Edit: November 21, 2007, 04:15:55 PM by Norm »
« Reply #9 on: November 22, 2007, 01:11:22 PM »
Bruce,
   Here's how I connect 4 stack of cells to make
it a 5 stack (6 volt)
 You can maybe see the other 3 stacks, the split
plastic pipe and a thin slice of dowel rod and
how they fit in the end in the background?
I take plastic pipe same size as the cell cut a
piece same diameter as the c cell saw lengthwise
with the bandsaw(remember the new bandsaw?...
best tool I ever got !) then I manage to spread it
and slip it over the ends of the batteries, then
put a spring between them.
 2 thin slices of dowel rod, same diameter as the cell, staple the slice
onto the ends of the pipe to make a cap.
  Now I drill holes in the ends and put a bolt
thru....head of the bolt on inside ....then drill
4 holes in two sticks ....the end of the bolts
slip into the holes ...after you put the wires
into the holes, the wires are configured to put
these series of cells parallel or series or 12
volt or whatever. These split plastic pipe grip
quite firmly onto the batteries....beautiful !
I think you'll like it....maybe even NTL will...
he kind of inspired me to this I didn't have pipe
big enough for the batteries to fit inside as
NTL suggested at one time....all I had was same
diameter as the cells....the only way I could do
it was split the pipe....OH CRAP ! this wouldn't
work either...well cut it in pieces...one cell at
a time....Hey these pieces of pipe are like
little clamps LOL ! AH Hah! Why not ? So goes
the way Norm thinks ! and it just won't stop !
 It keeps getting better and better ! LOL !
      Time for Coffee !
     ( :>) Norm.
« Last Edit: November 22, 2007, 01:11:22 PM by Norm »
elvin1949
« Reply #10 on: November 22, 2007, 06:14:43 PM »
 Feral Air made mention of a automatic hub/derallier
bike auto shifter.
 I have one on a 26 inch wheel.If you think it could be used on this project.Drop me an email.
 You can have it,all i need is an address,it's free
I will even pay shipping.It is just in my way
maybe you can get some use out of it.
Elvin
« Last Edit: November 22, 2007, 06:14:43 PM by elvin1949 »
Yes indeed....thank you very much
« Reply #11 on: November 23, 2007, 10:09:42 AM »
Yes...I would be glad to have it, Elvin, I will
be able to get a lot of use out of it.
 I'll E-Mail you my address....
Thanks a lot ....
         ( :>) Norm.
« Last Edit: November 23, 2007, 10:09:42 AM by Norm »
batt packs
« Reply #12 on: November 24, 2007, 08:02:50 AM »
Norm;
   Sorry , didn't mean to take so long getting back to you. Thanksgiving is a big deal for us. 7 stses worth of people converge on in-law house and it's a wondeful time.
I have about 1/2 dozen of those pack charged for a different project for our DBA, < he's getting his recumbent trike ready for the nite ride > and I'm helping build the light poles. The packs break down into pefect 2 10VDC 1300ma sets and this <with G-'s LED help> lights up the LEDs perfectly.
Anyway , come Monday I'll pack up those 1/2 dozen and send them out to the same address as before, along with a new surprise box for you. Call it an early Christmas present:-). I will have more as soon as the tester finishes testing them, will then send them by the 6pack if you want/need.
Happy Thanksgiving!!
« Last Edit: November 24, 2007, 08:02:50 AM by Bruce S »
Re: batt packs
« Reply #13 on: November 24, 2007, 01:30:05 PM »
Yes...I've been busy myself understand how it is.
I've got these 20led camp lights that take 4 AA
alkaline batteries...that's about 6 volts and
something like 175Ma....anyway left the 4cells in
series but paralleled the stacks giving me 4.8 or
5.6 max and 5200 Ma/hr  (I guess??) anyway I left
these on all night from 1Am when I got up at 6AM
they were just a kerosene lamp bright and the
voltage had dropped to about 4.6 from 5.2 at 1
so....I guess I'll have to have a double or triple pack like that ....I was thinking of adding 1 cell per stick or using the 5 cells and paralleling about 6 'sticks' to make a 6 volt
7.8 amp/hr battery ....but then at a higher voltage
it might draw more current and drive the LEDs
too hard.
   Ever charge a battery with pedal power?
Might be easy pedaling but takes a looongg time !
Makes you appreciate 14 cents a kilowatt/hr or
whatever it is now....
   I was just laughing with my sister about the
time Dad hit the ceiling because the bill had
went over a $1 for that month.....that was a
long time ago.
                 ( :>) Norm.
« Last Edit: November 24, 2007, 01:30:05 PM by Norm »
Re: batt packs
« Reply #14 on: November 26, 2007, 10:26:53 AM »
Norm;
 Pedal power? nope or should say not yet:-)
I stick these onto the little 12V 1.5 watt panels and have them charged up by it:-) I find that if I break them into 2 10V packs and let the charger work with that , I'm sure to have a nice set of batteries charged for my tests.
I have been messing with a different set of packs, much newer, but only setup for 18V in a 3x5 bank, and they are not as easy to reconfigure as these old ones are.
Perhaps I'll send a few of them along for you to fight with as well. 2 of them will make a nice ~12 unit since there'll be 10 per set.
By my numbers.... that system would last better than 24hours.
How about putting up a picture of that 20LED light:-)?
« Last Edit: November 26, 2007, 10:26:53 AM by Bruce S »
