Author Topic: New rotor machined  (Read 1096 times)
Sillyboy
New rotor machined
« on: June 12, 2008, 09:29:44 AM »
My motor conversion project continues.
Now i have a new solid iron rotor and the aluminum gasket ready. I got them worn out  bearings changed too.
I certainly consider buying a cheap metal lathe next time. Latheing was expensive. 200 euros.
Magnets i ordered from magnet4less and they came home alright, 40 pieces of 3/4 x 3/8 N42.
Next task would be to paint the motor and to drill holes for magnets.
« Last Edit: June 12, 2008, 09:29:44 AM by (unknown) »
Re: New rotor machined
« Reply #1 on: June 12, 2008, 07:33:35 AM »
Hi Sillyboy
 The sleeve appears to be longer than the rotor.Do you have to cut it yet?
 Looks good and have fun.
« Last Edit: June 12, 2008, 07:33:35 AM by vawtman »
Sillyboy
« Reply #2 on: June 12, 2008, 02:18:02 PM »
Yes sleeve is longer. I did it on purpose to fit more magnets. The purpose of outer part of the sleeve is to hold itself together.
« Last Edit: June 12, 2008, 02:18:02 PM by Sillyboy »
« Reply #3 on: June 12, 2008, 07:07:29 PM »
(the purpose of the outer part of the sleeve is to hold itself together)?Maybe i'm way off here but the sleeve can't come in contact with endbells.
« Last Edit: June 12, 2008, 07:07:29 PM by vawtman »
« Reply #4 on: June 13, 2008, 12:17:33 AM »
He's got the length of the windings plus a bit at each end as there seems to be no fans.
« Last Edit: June 13, 2008, 12:17:33 AM by Flux »
