I got my solar power system operational 9 months ago in September 2007, but the panels have been sitting on the ground up until now. Here is the Before picture...
So I've Assembled the pool, installed the pool solar heater, built an adjustable mount and put my panels up on top of the Shed. This is the After picture...
I made a frame for the panels out of 2x4 wood studs, painted it with outdoor Primer and screwed it together with 3 inch (75mm) screws. Then I made a separate Foundation Framework and screwed it down to the top of the shed. The last step was to connect the Panel Frame to the Foundation at the front using hinges. I can tilt the entire set of solar panels up and down for Summer & Winter settings. No kind of tracking here, just seasonal adjustment. You may notice that it is exactly big enough to hold 3 more Harbor freight panels...
The front of the shed faces directly South but my house rises fairly high just to the East of my shed. It's not a bother in the Summer and the panels are never shaded. However in the Winter the panels don't get Sun till after 11:AM in the morning so the tilt of the shed roof points the panels to more open sky in the Winter. I have the angle temporarily set using the Unpainted Woodblocks. I want to make some kind of system that will easy set it for Summer or Winter Sun angles. I haven't quite figured this part out yet. I think I'll mount with hinges, some long pieces of wood that will open up and stand the Frame up for Winter, then fold down with woodblocks on the back of that, setting it to Summer Sun. Then I'm thinking about holding it down with Bungee Cords so the wind can't flip it over.
OK , That's Me having too much Fun with the system posted here...
http://www.fieldlines.com/story/2008/3/4/6303/63451
Plenty of more projects coming. Upgrade my ghurd dump controller to 2 stages for when I add more panels and the wind genny. I need to make an input/combiner for all my standard and secret power projects. I need to make a tower/mast system soon too. So many projects, so little time . . .
W o o f -={(
