Author Topic: High speed turbine  (Read 2728 times)
High speed turbine
« on: August 24, 2008, 07:25:35 PM »
I 'm tearing this unit down one more time for a grinding and painting . Installed just behined the front bumper I takes off at 30 mph and is quiet enough at 75 I don't hear it at all I neeeded higher  voltages for the HHO Cell to get the volume up with distilled water . I thought it looked so much like a Vawt you'd get a kick out of scaled down 120 degree blade configuration.
The stator is tapped 6 times at 20 and 30 ohms per . It runs 10 to 75 volts around 1 to 1.3 amps per tap . The taps are rectified and paralleled and series in over battery voltage  . The cell is on a lawton pmw at 2. 5 to 4 amps(when it gets hot ) with good volume .
« Last Edit: August 24, 2008, 07:25:35 PM by (unknown) »
Re: High speed turbine
« Reply #1 on: August 24, 2008, 01:28:24 PM »
Here's b side
« Last Edit: August 24, 2008, 01:28:24 PM by tecker »
spinningmagnets
« Reply #2 on: August 24, 2008, 02:23:13 PM »
Do you have any pics of the PMA or the gen guts before it was covered?
« Last Edit: August 24, 2008, 02:23:13 PM by spinningmagnets »
« Reply #3 on: August 24, 2008, 02:39:09 PM »
 I'm taking the gen down for varnish and paint I'll take some.
« Last Edit: August 24, 2008, 02:39:09 PM by tecker »
« Reply #4 on: August 24, 2008, 02:46:25 PM »
Thats pwm . Man!
« Last Edit: August 24, 2008, 02:46:25 PM by tecker »
« Reply #5 on: August 26, 2008, 07:04:24 AM »
The rotor and stator .I screwed up the wire hauling it around a mounting it in diferent places . Replace that  urethane the stator and several coats of pint and a sealing disk on the mounting side
« Last Edit: August 26, 2008, 07:04:24 AM by tecker »
« Reply #6 on: August 26, 2008, 07:08:34 AM »
 Stator I hit the wong button
« Last Edit: August 26, 2008, 07:08:34 AM by tecker »
« Reply #7 on: August 29, 2008, 07:02:22 AM »
hey tecker ,
i had to do a bit of you tube research to figure out what your post was about .
nice use of a cieling fan/savonius
does the  pwm work with various input voltages?
« Last Edit: August 29, 2008, 07:02:22 AM by electrondady1 »
