Don't go cutting any more off the blades until you have had enough wind to do some thorough testing. You can't get anything in very light winds and I think you are very close to the mark if you saw 5A at 10 mph.
It is all to easy to mess about in winds that aren't capable of doing anything and then realise you have gone too far when you do get a good wind.
There is nothing available below 7mph and even if you shorten the blades to get a few mA it will seriously mess up the performance in the better winds.
Keep the swept area as large as you can consistent with cut in at 7mph ( or even
Doubling up on those magnets gives you something quite reasonable, I don't have time to check figures now but I suspect you are close to the mark at present so give it a real good try without altering things.
