Author Topic: October  (Read 1130 times)
Capt Slog
October
« on: November 07, 2008, 01:57:48 PM »
October seemed to come in with a bit of a vegeance in the UK, a bit of a foretaste of a predicted cold winter.
My house is what we call here a semi-detached (you might too in the US, I don't know) meaning I share one wall with my neighbour.  Unfortunately she, (a Liv Tyler look-a-like ), has all the 'south side' having walls facing west, south and east and I have walls facing west, north and east.  This means that my house is a little colder.
It was also built in 1910, when cavity walls were something a builder put in if he employed a drunk brick layer.  A thrid of the wall area in the north facing bits is taken up by chimney breasts, from when there was a coal fire in every room even in the bedrooms which must have been very cosy, and this leaves two alcoves around 4 feet wide.  The surfaces of these can be cold enough to attract condesation!
So I thought insulation was the way to go.  I bought some battons and crewed these onto the wall, and these form supports for a sheet of 12mm plywood.  I could have used plaster board but to get a sheet of it that size is difficult and hard to handle, plus I can easily put shelves on the ply.  I put some bubble wrap in as insulation on the first one I did, but I think I will upgrade this on subsequent ones.
The result after a coat of paint, decorative textured paper and then more paint is very pleasing, in that you can't tell it's been done, and that is what I aimed for.  It's also a lot warmer to the touch.  As it seems a workable solution, I'm going to carry it on through the house, using wood or plaster board as the need dictates.
I also insulated the one window in the house that wasn't double glazed using some of that twin-wall polycarbonate sheeting.  There was a raised portion of the inner frame around 1" from the original glass, so I cut a sheet of the twin-wall to fit onto this and sealed it there.  The result is instant triple glazing and this has made a huge difference to the area near that window.  The original glass was the obscure patterned stuff anyway, so cosmetically it's not a lot different.  I've read of others using bubble wrap and I have tried that in the past myself, but Mrs Slog likes things looking bit more neat and permanant, and tghis fitted the bill nicely.
« Last Edit: November 07, 2008, 01:57:48 PM by (unknown) »
spinningmagnets
Re: October
« Reply #1 on: November 07, 2008, 11:13:11 AM »
Dear Capt Slog. I'm glad to hear this worked out well for you, could you indulge me with a couple pictures?, I'd be most grateful.
If you don't mind me asking, how would you normally heat your living areas on a cold day?
« Last Edit: November 07, 2008, 11:13:11 AM by spinningmagnets »
Re: October
« Reply #2 on: November 08, 2008, 07:17:04 AM »
Yes, heating degree days for this October were of the order of twice as much as last October in London at least.
« Last Edit: November 08, 2008, 07:17:04 AM by DamonHD »
Re: October
« Reply #3 on: November 09, 2008, 03:01:51 AM »
early winter here as well--colder than normal..
than again what is normal !!!!!!!!!!!!
« Last Edit: November 09, 2008, 03:01:51 AM by hiker »
Capt Slog
Re: October
« Reply #4 on: November 10, 2008, 02:19:50 AM »
The one I've done so far was a bit of a rush I'm afraid, and I didn't think about photos at the time.  Now I have a feel for what I'm doing, I'll take pictures.
The house is heated by gas central heating, there is also a gas fire in one room for a bit of extra heat (or when the whole system isn't required) and a log burner in another room.  It's not the best system I'll admit, but the way the house is made its the only thing possible without really major works.
« Last Edit: November 10, 2008, 02:19:50 AM by Capt Slog »
