Author Topic: too much current  (Read 1008 times)
2windy
too much current
« on: November 20, 2008, 09:25:45 PM »
Just checked the voltage going into my dump load, it read about 15 volts then started going down til it shutoff. The amps read about 7 amps. My battery bank voltage is 28.5. My thoughts were when it dumped power it dumped the same voltage as your batteries and the current just increased..
« Last Edit: November 20, 2008, 09:25:45 PM by (unknown) »
Re: too much current
« Reply #1 on: November 20, 2008, 03:03:45 PM »
This dump is pwm. It will dump at battery volts but the thing goes on and off.
If your battery was at 28v and the pwm was 50% you would have 28v square waves with 50% duty cycle. A normal mean reading meter would read this a 14v.
With a mean reading voltmeter you will see a dump voltage proportional to dump current  and the mean current will be the mill current minus anything still charging the battery. When duty cycle reaches 100% you will see battery volts across the dump load and it will be a steady current equal to battery volts divided by load resistance.
If it worked as you implied the current would be constant and all or nothing.
« Last Edit: November 20, 2008, 03:03:45 PM by Flux »
2windy
« Reply #2 on: November 20, 2008, 03:16:27 PM »
Thanks again Flux... its sounds like it is working okay. It is doing exactly what you say. I didn't know quite how it work.
« Last Edit: November 20, 2008, 03:16:27 PM by 2windy »
