Author Topic: Turbine works well  (Read 2389 times)
97fishmt
Turbine works well
« on: November 12, 2009, 01:55:46 PM »
It's up!
The tail is a little light and the vane is too small but the boom is ok.
This worked before with less offset. So it furls too soon right now. It's
an easy fix.  It was a good thing it was very windy the next day after it went
up. Of course there was no wind when I put it up. It starts to turn out of the
wind at 20 amps and then with a little more wind it turns completely out and stops.
When it calms down it will turn back into it though.  So the tail ether needs to
be heavier or a larger vane.  Or decrease the angle at the tail pivot.
Here is the grip hoist and the old boat winch for the counter action when
it gets to almost vertical.
I'll need to come up with a better anchor point for the winches.
This worked for now but I don't think so with a lot of snow with the grip hoist.
I bought 200' of cable for the hoist, it goes through two pulleys and down to
the lift anchor and I still have plenty of cable left so I'll come up with something.
Wow it is amazing that there is no turbulence now!
« Last Edit: November 12, 2009, 01:55:46 PM by (unknown) »
cardamon
Re: Turbine works well
« Reply #1 on: November 12, 2009, 04:38:02 PM »
nice looking tower. How tall and who made it?
« Last Edit: November 12, 2009, 04:38:02 PM by cardamon »
97fishmt
« Reply #2 on: November 12, 2009, 04:56:18 PM »
Hello
It's a 64'Rohn 45g with a few modifications to make it tilt up and the top to accept the turbine.  It is very robust, I definitely recommend one to those looking to put up a turbine.  Thanks
« Last Edit: November 12, 2009, 04:56:18 PM by 97fishmt »
DanB
    • otherpower.com
« Reply #3 on: November 12, 2009, 05:28:09 PM »
I think you meant 'increase' the angle at the tail pivot...?  to make it furl later.
« Last Edit: November 12, 2009, 05:28:09 PM by DanB »
97fishmt
« Reply #4 on: November 12, 2009, 05:43:46 PM »
Oh! your right Dan.
It was the last thing I looked at when I took it down
and when looking at it on it's side I guess it looked different
and was just a thought as I was leaving the cabin.
Thanks. I might have tried going the wrong direction to solve
the problem.  Any way I'm sure the angle is more than 20 degrees so
that is not the solution. A larger vane is in order.  Thanks again.
« Last Edit: November 12, 2009, 05:43:46 PM by 97fishmt »
97fishmt
« Reply #5 on: November 12, 2009, 06:11:49 PM »
Actually Dan I know it needs more surface area on the vane but, by watching
the way it acted in the strong gusts, I guess I was wanting more action from
the tail and for the machine to balance and keep it into the wind and add a stop before it got to the top of its function . It maybe going past the 90 degree mark
and not being able to fall back down. This is my GUESS.  Or just a more weight issue.
Is that right or do I investigate the pivot.  Since this is not really the way your turbines are constructed the pivot is only angled one way.  In reading Hughs book it
states there are two angles that need to be observed.
« Last Edit: November 12, 2009, 06:11:49 PM by 97fishmt »
« Reply #6 on: November 13, 2009, 12:49:47 AM »
If you only have the vertical angle on the tail pivot and it is pointing directly back it will go over centre as you suggest.
Over most of the working range the forces on the tail will be wrong, it will have very little control at the point where it starts furling.
As well as the 20 or so degree vertical angle the hinge needs to be oriented so that the free hanging position of the tail needs to be about 45 deg away from the straight back direction away from furling. The actual angle may work anywhere between 30 and 60 deg, it is a compromise whatever you do, and the compromise has various effects.
It is possible to include both angles in the same physical set up, it needn't be done as two angles physically separate ones but if you do it as as one compound angle it is very confusing unless you really understand what you are doing.
You will never get a satisfactory result with just the vertical angle pointing straight back.
« Last Edit: November 13, 2009, 12:49:47 AM by Flux »
97fishmt
« Reply #7 on: November 13, 2009, 10:13:36 AM »
Thank you Flux as usual you are a wealth of information and really help this site along.
In observing the tails actions it looked as it could not steer it into the wind.
I didn't think it was so critical with the tails function only to put it into the
wind and turn the machine out of it.
I see how the compound angle will work more to steer it into the wind, more torque.
And a larger vane to come from the other side of straight back to point it ahead.
I should have put a top stop on but was excited to get it up.  I have 19 inches from
the blades to the tower so I wasn't worried about the tail hitting the blades.
It rises up and hits the back of the motor and it is past and over the top of its
rise.
I have more of an idea now of how it should be.  Thanks
« Last Edit: November 13, 2009, 10:13:36 AM by 97fishmt »
« Reply #8 on: November 13, 2009, 03:07:46 PM »
If it hits the back of the motor you've got a stop.  B-)
You might want to mount a bumper there to cushion the motor/boom contact to avoid damage - and something above that, sticking out farter, to block the boom if it then tries to slide up on its pivot and go over the motor and into the blades.
« Last Edit: November 13, 2009, 03:07:46 PM by Ungrounded Lightning Rod »
97fishmt
« Reply #9 on: November 13, 2009, 03:23:00 PM »
Yes I will add a stop.
Right now it actually is cushioned by the very stiff wires coming out
the back of the motor.  I just didn't think it would go that far.
I had a stop on the last build and it worked great.
I shouldn't have skipped it.
No harm done just didn't get big power.
There is a fastener to keep the boom from riding up.
It was cool to see it furl so nicely though,  just another step
and I am almost there.  Thanks for the comment
« Last Edit: November 13, 2009, 03:23:00 PM by 97fishmt »
Dave B
    • DCB Energy Systems
« Reply #10 on: November 14, 2009, 11:46:56 AM »
It's what works for you and your machine. There are some general design specs. for the "standard" machine mostly built here and promoted with a couple of great books but it's not etched in stone. Experiment, have fun, do your own thing. If your machinre is different from the start then throw out the "should be this, should be that talk" it's your own machine and all the new variables that go with it. Dave B.
« Last Edit: November 14, 2009, 11:46:56 AM by Dave B »
DCB Energy Systems
http://dcbenergy.com/
97fishmt
« Reply #11 on: November 14, 2009, 06:13:59 PM »
Thanks Dave.
I have learned like the rest of everyone.  Mostly from just trying stuff.
It has all led me here so far.  It has been pretty serious for some time,
I am pushing too many amps, I think, around 80 at 15 volts.
My summer was really about getting the tower done and putting up what was
working before.
I changed the motor platform and wiring, my wire run comes in at 0.2 ohms
in resistance from the turbine to the rectifiers at the batteries.
This is good and the tower is solid,  so I want to use the new platform
to start experimenting with the higher voltage motors I have been stock
piling.
Blade changes and different power curves of different motors will all need
some tweeking.  Let the fun begin.
« Last Edit: November 14, 2009, 06:13:59 PM by 97fishmt »
97fishmt
« Reply #12 on: November 15, 2009, 01:14:55 AM »
That should be 2.0 ohms
« Last Edit: November 15, 2009, 01:14:55 AM by 97fishmt »
DanB
    • otherpower.com
« Reply #13 on: November 15, 2009, 07:41:36 AM »
One concern I have about it (just realized as I read this post again) - looks as though the cord is wrapped around the tower - it looks like this could prevent yawing and furling if it gets tight.  Is that the case or am I misinterpreting the pictures?  I would have the line running right down the center of the tower so it can twist up, rather than wind its way around the tower.
« Last Edit: November 15, 2009, 07:41:36 AM by DanB »
97fishmt
« Reply #14 on: November 15, 2009, 01:04:05 PM »
I see what you are looking at in that first picture.
That is the angle support. The wires are run down the center
of the tower.
I tried to straighten up the picture, I guess it is a digital thing
making it look kind of rough around the edges.  It seemed like all the
pictures I took  made it look like the tower was out of plumb.
I did plumb it and tighten the guys to pretty good perfection,  up and down
work well and comes up to plum.
New camera or software on this end?
Thanks Dan I love your site and your work.
« Last Edit: November 15, 2009, 01:04:05 PM by 97fishmt »
97fishmt
« Reply #15 on: November 15, 2009, 01:21:24 PM »
« Last Edit: November 15, 2009, 01:21:24 PM by 97fishmt »
