Author Topic: Got tired of straining my back  (Read 1894 times)
Rover
« on: January 24, 2010, 09:05:07 AM »
My short test mast is used to hold up small mills, and in the past with light ECMs etc, it hasn't been a problem to hook a rope to the mast and raise it will standing on the roof of the shed.
This changed when I beefed up the mast to 2" schedule 40 steel , and mounted a treadmill motor. Top of the mast weight is ~ 50 lbs. Took me 4 or 5 attempts to pivot it back up , and some pain pills later.
Thi time, I used garage door springs to take some of the load, and it worked. Reduced the perceived weight by half and had no trouble pulling it back up. I used 2 springs inline, but probably would have been better with one.
I did run a safety cable through te springs.
Photo with it down.
..and back up
« Last Edit: January 24, 2010, 09:05:07 AM by (unknown) »
Rover
Re: Got tired of straining my back
« Reply #1 on: January 24, 2010, 09:38:33 AM »
Well...or you could have used counterweights...
3 or 4 5gallon buckets...bout 6ft up fill em with water initially till it almost raises the
pole.
  Nice shed....were are you at with no snow and
nice green grass....?
« Last Edit: January 24, 2010, 09:38:33 AM by Norm »
« Reply #2 on: January 24, 2010, 09:40:39 AM »
rover;
I certainly hope a gust does not flip the shed over! That type here usually is not attached to the ground just  sit on piers or skids.
Interesting setup. Too bad you have so many close tall trees.
« Last Edit: January 24, 2010, 09:40:39 AM by TomW »
Rover
« Reply #3 on: January 24, 2010, 09:51:17 AM »
Grin, I built the shed... how many you see with a deck?
Its anchored and properly framed, where rhe mast is the interior wall is 8 2x4s against each other.
Norm... Norfolk VA
« Last Edit: January 24, 2010, 09:51:17 AM by Rover »
Rover
Rover
« Reply #4 on: January 24, 2010, 11:24:04 AM »
Wind is not one of my bigger worries.. this is hurricane Isabel
« Last Edit: January 24, 2010, 11:24:04 AM by Rover »
Rover
« Reply #5 on: January 24, 2010, 12:57:57 PM »
Here we would just say it was now a houseboat!
« Last Edit: January 24, 2010, 12:57:57 PM by TomW »
Rover
« Reply #6 on: January 24, 2010, 01:51:38 PM »
Notice.. it did not float... properly anchored in the true sense of the verb
« Last Edit: January 24, 2010, 01:51:38 PM by Rover »
Rover
