Author Topic: Baldor treadmill motor update  (Read 3419 times)
Rover
« on: January 29, 2010, 05:16:43 AM »
Brought down my treadmill motor last weekend to swap out the blades etc.
previous post(http://www.fieldlines.com/story/2010/1/24/957/57415) for pics with the new blade set
The treadmill motor is a substantial Baldor, 2400rpm/90vdc/21amp. When I initially put it up 3 weeks ago, I used 3 regular hornet blades (56" swept) on a small aluminum hub I had lying round. With that configuration it was just taking too much wind to start up, even acknowledging that these smaller units usually do.
My bench tests had shown a cut-in of about 400 rpm at 12.5 vdc, so I knew I could get power out of it if could just get it to spin up so I made the following changes.
In the past I have had pretty good luck using a 6 blade configuration on ECM conversions. The six blades are 28" hornets cut back to 22" .
I used the 6 blades this time, on blade extensions off the hub to get a final diameter of 52" , and I increased the weight of the hub using a steel one of about 5 lbs.
The effect of the changes was dramatic, It now starts up easier and will run longer, probably partially due to the increased weight of the hub getting past the friction of the brushes.
Overnight last night I saw a peak output of 14.1 Amps at roughly 12.5 v, higher than I expected to ever see (no wind data, but hasn't been over 20mph I don't think ). So I'm actually happy with the unit.
« Last Edit: January 29, 2010, 05:16:43 AM by (unknown) »
Rover
Rover
Re: Baldor treadmill motor update
« Reply #1 on: January 30, 2010, 10:49:34 AM »
It hit 26.4 A today at 13v...didn't think it had it in him
Wind is a steady 24 mph, must ave been a heavy gust
« Last Edit: January 30, 2010, 10:49:34 AM by Rover »
Rover
taylorp035
« Reply #2 on: January 31, 2010, 10:41:52 AM »
I just finished last night my 50" 2.5 hp treadmill motor last night.  My cut in is at 360 rpm.
I found that my old 55" (I think) blades were only about 1-3 degrees at the tip, so I made some that are much steeper, maybe 10 degrees.
26.4 amps, I am impressed, I hope mine can do that.  What are your motor specs?
Mine are 30 rpm/ volt, 16 amps continuous, 150 volt @ 3960 rpm.
« Last Edit: January 31, 2010, 10:41:52 AM by taylorp035 »
Rover
« Reply #3 on: February 01, 2010, 04:21:54 PM »
motor specs ... baldor. 90 vdc, 2500 rpm , 21 amp (bench cut-in 400 rpm)
does amazingly well.. using cut back hornet blades... check my Diaries for more data.
« Last Edit: February 01, 2010, 04:21:54 PM by Rover »
Rover
