Not sure if this is the place to ask the question, if not, got any air con forums to recommend?
Question, if My new 8KW invereter Daikin air con has just been turned on with room temp at 30Deg, the set point on the thermost is 21Deg,
The air con will come of full boar at 8KW
8000 watts / 240Vac By 0.8 =26 AMPS AC
OK so slowly the room temp drops to 21deg and the inverter technology kicks in and is now maintaining the temp at 21deg
the question is (or roughly) how many KW is the unit using to maintain the 21 Deg (assuming the outside ambiant is the same (30deg)
or is this info something more for the daikin R&D techs would have.
just would like to know what kind of AC amp draw the unit will have when maintaning 21deg...
...Richard
