Author Topic: will a old Generator work?  (Read 1675 times)
greenkarson
« on: February 15, 2009, 10:36:48 PM »
i have a old generator a honda 3500. gen works fine motor shot i have about 5 feet of head lots of gpm's. Any ideas how to make this work? will i get enough horse power out of the water to produce any thing. or can i charge batteries with this or should i look more into alternators  (I only use about 250 to 300 watts running power couple of lights small tv.)
« Last Edit: February 15, 2009, 10:36:48 PM by (unknown) »
bob g
    • microcogen.info
Re: will a old Generator work?
« Reply #1 on: February 15, 2009, 06:43:43 PM »
that one will be more trouble than it is worth i am afraid,
if you need only a couple hundred watts, use one of those tapedrive motors
or the like, would seem like a better idea,
or do a purpose built alternator or a zubbly conversion makes more sense to me.
bob g
« Last Edit: February 15, 2009, 06:43:43 PM by bob g »
sk windpirate
« Reply #2 on: February 15, 2009, 08:10:59 PM »
5 ft of head and lots of gals per hour would make a excelent system.
Your honda might do you more good if you use the copper to wind a low rpm perment magnet motor. With that you would do much better.
Get a flow rate and someone should be able to help you out.
« Last Edit: February 15, 2009, 08:10:59 PM by sk windpirate »
