Author Topic: bicycle anometer  (Read 2028 times)
bsafe
bicycle anometer
« on: February 12, 2009, 11:44:26 PM »
I have googled the board looking for the conversion number for a bicycle computer based anometer built using the cup assembly sold by Otherpower.
  Googling, I found the numbers 1320 and 2682 to program the bike computer. The cup assembly has a diameter of 8.5 inches and the magnet for the reed switch is located one inch from the center of the cup assembly. Thank you in advance. bsafe
« Last Edit: February 12, 2009, 11:44:26 PM by (unknown) »
imsmooth
Re: bicycle anometer
« Reply #1 on: February 13, 2009, 08:42:26 AM »
I have a sigma computer and use 1440 for mph.
« Last Edit: February 13, 2009, 08:42:26 AM by imsmooth »
« Reply #2 on: February 14, 2009, 03:12:41 PM »
 The distance of the magnet from the center is
nothing to do with it....it's only going to count
once per revolution.
 The little phamplet that comes with the digital
bike speedometer gives the formula for any sise
diameter wheel.
http://www.instructables.com/id/Digital-Anemometer-wind-meter/
According to this author he programmed it to a
wheel 3 times the size so it reads 3 times actual
speed..... ( I put cups on 10 inch arms so digital
thinks it's a 20 inch wheel)
Google how to program a digital bike speedometer.
« Last Edit: February 14, 2009, 03:12:41 PM by Norm »
bsafe
« Reply #3 on: February 14, 2009, 07:43:19 PM »
I googled this board and the interweb, then I asked the question. As mentioned here and other sources there is a certain amount of "slip" that occurs when using the bicycle computer in this application.
Calibration for a fluid  is a bit of  a different proposition from a bicycle wheel contacting pavement. I am curious what calibration number someone that had built and calibrated the computer as a wind speed measuring device (the RPM device will be next) came up with.
I used The diameter of the cup assembly and the readings seemed unreliable.
« Last Edit: February 14, 2009, 07:43:19 PM by bsafe »
winDorlose
« Reply #4 on: February 15, 2009, 08:54:08 PM »
When I made mine I took a ride in the car and experimented until I was satisfied will the results. I used a gps on a calm night.
« Last Edit: February 15, 2009, 08:54:08 PM by winDorlose »
bsafe
« Reply #5 on: February 16, 2009, 06:41:36 PM »
I like the GPS solution, how high above your vehicle did you mount it? I relied on math the firt time I calibrated       and came up with 1550 which did not "feel" right. I stopped at several T.V. stations to see If the weatherperson had a handheld Kestral wind meter, but no luck. I will try the GPS method next probably mounted on my bicycle to minimize the disruption from the vehicle.
« Last Edit: February 16, 2009, 06:41:36 PM by bsafe »
