Author Topic: Rectifier Wiring Help Please??  (Read 806 times)
oldbzzrd
« on: January 04, 2007, 02:42:59 AM »
Hello,
I am building the "homebrew wooden alternator" on Other Power's website and need info on how to wire the bridge rectifier onto the two lines coming off the 18 coils hooked up to each other in series single phase.
I made a wind turbine from plans on picoturbine.com and hooked it up to rectifiers alright but it was in "star" confirguration and 3-phase.  Can someone tell me EXACTLY how to hook the two single phase wires up to the 4 spades off the rectifier?
Thank you!!
Mary
« Last Edit: January 04, 2007, 02:42:59 AM by (unknown) »
RP
Re: Rectifier Wiring Help Please??
« Reply #1 on: January 03, 2007, 08:01:46 PM »
Mary,
The rectifier terminals will be marked.  Two opposite corners will either say "AC" or have a "~"(squiggly line) on them.  This is where the alternating current from the generator comes into the bridge.  These get connected to the two wires from the stator.  There's no polarity on these so either wire can go to either AC corner.
The two other corners will be marked "+" and "-".  These are the postive (+) and negative (-) DC terminals from the rectifier.
Hope this helps
« Last Edit: January 03, 2007, 08:01:46 PM by RP »
oldbzzrd
« Reply #2 on: January 03, 2007, 10:06:57 PM »
Hello,
Thank you!!!!  I wasn't sure what to do with the second wire off the single phase and just leave it alone like in the "star" 3-phase or not.
Thank you!!!!
Mary
« Last Edit: January 03, 2007, 10:06:57 PM by oldbzzrd »
RP
« Reply #3 on: January 04, 2007, 06:23:55 PM »
Please post some pictures of your unit when you can!
« Last Edit: January 04, 2007, 06:23:55 PM by RP »
