So, I have my two 45 watt (HF) panels hooked up in parallel charging a 12v battery array.
The batteries are 6v and I have six of them total.
When I tested the current generated by the panels, it is showing 3.25 amps. At the time, my battery was at 12.65 volts. I figured 3.25 amps * 12.65v = 41.11 watts. Seems a lot lower than I expected. Both sets of panels were fully exposed to pretty good sunlight at the time.
I did a simple test to make sure both panels were properly hooked up. I covered both with large towels and checked the charge controller. The LED was OFF as expected. I then uncovered part of the panel at a time (exposing only single panels at a time (each 45watt array consists of 15w smaller panels). Each time I exposed a single panel, the LED was ON. So, all my panels must be properly connected.
Is 3.25 amps @ 12.65 volts normal output? Maybe watts are calculated using open voltage? If so, then it would be 3.25 amps * 23.57 volts = 76.6 watts. That seems a bit closer, especially considering sun wasn't angled exactly perfectly (but it was pretty close).
thoughts?
